Delonghi ECAM 23.450S: Milk Frothing Issues, New Milk Container (Catalog No. 706-UC-2867)
michal250490 17115 18
Why won’t a DeLonghi ECAM 23.450S draw milk into the frother, and which parts should I check or replace?
The milk circuit usually fails because the solenoid/steam path is dirty or the Venturi adapter no longer creates enough vacuum, not because of the milk container itself. A loud humming solenoid should not happen; it should switch with a clear “pop”, and that kind of noise points to contamination inside the valve, so descaling/cleaning or replacing the valve is advised [#16263267] In this model there appears to be only one solenoid valve, catalog 5213218381, and the same model can use different internal variants, so the exact machine number should be checked before ordering parts [#16263858][#16263885] If milk still is not sucked in after the valve is replaced, the next likely fault is the frother adapter/orifice: a worn or de-calibrated hole in the adapter is said to be the cause in most cases because it is what creates the vacuum needed to pull milk [#16277452] Also replace the two green O-rings on the outlet where the milk container presses, because leaking there can prevent proper suction [#19100878]
  • #1 16261481
    michal250490
    Pretty standard theme for this model. The machine does not whip milk. I got it from my parents without a milk container (lost) and wanted to fix it so that it works 100%. Until now, he only made coffee and hot water, and when it was given to me even as the milk container was, the milk maker did not froth. Okay, let me get to the point. I ordered a milk container from North.pl (Catalog number: 706-UC-2867) I connected and the milk frothing does not work. I am writing about this container to eliminate it from suspicion. It is new and certainly not clogged.
    Symptoms: when I turn on the capuccino mode or frothing milk, the milk is not sucked into the tube, sometimes the level will rise a little, but never suck the milk. Only water vapor and water are flowing from the nozzle. It is also a symptom that instead of sucking milk it blows into the container. This can be seen by the bubbles forming in the container. In a word, the pressure is not enough to draw milk. I read similar topics on the forum, but I don't care about tips like replace all valves and something else. I would like to come to what actually does not work and replace a specific part / parts.
    I undressed the express. I attach photos. In the subject https://www.elektroda.pl/rtvforum/topic2959661-30.html
    there is a post in which two solenoid valves and a nozzle adapter are indicated as potentially damaged. I exclude the container, because as I mentioned I bought a new one.
    I located only one of the solenoids, I don't know where the other is. The adapter has cleaned, as well as the tube that goes out of it to the solenoid valve. I would like to come to the cause of the damage step by step.
    My first question is where are the other solenoids and can I clean and check them. I will add that I have the ability to control solenoid valves from an external source (230V AC) after unscrewing and I have access to compressed air, so I could also see if they work properly. My guess is that the solenoid valve in the picture works on the principle that when it is not controlled, it passes water from the top to the left, while in the event of control the left drain is closed, while all the water should go to the right. I might be wrong?
    I can be wrong in all these suspicions, so please help me what to clean / check / replace in order for the machine to froth the milk.
    However, it seems to me that this is due to the insufficient flow of liquid / vapor through the adapter, which does not create a sufficient vacuum to suck the milk through the hole in the adapter (between the larger and smaller O-rings). And in fact, maybe the solenoid valves do not fully open (damaged) or this adapter is damaged, so this vacuum is not there. Please help.
    I attach a video from the test of the aforementioned solenoid valve. If it is not pumped, it feeds the entire air stream to one side (not towards the nozzle adapter), after actuation a loud humming sound is heard, and the flow in the direction in which the nozzle is normally located is minimal. Is it possible that the vacuum is too low to draw milk from the container?
    • 20170208_103224.mp4 (47.65 MB) You must be logged in to download this attachment.
    • Delonghi ECAM 23.450S: Milk Frothing Issues, New Milk Container (Catalog No. 706-UC-2867) 20170208_081038.jpg (4.79 MB) You must be logged in to download this attachment.
    • Delonghi ECAM 23.450S: Milk Frothing Issues, New Milk Container (Catalog No. 706-UC-2867) 20170208_080500.jpg (4.35 MB) You must be logged in to download this attachment.
    • Delonghi ECAM 23.450S: Milk Frothing Issues, New Milk Container (Catalog No. 706-UC-2867) 20170208_080454.jpg (5.3 MB) You must be logged in to download this attachment.
    • Delonghi ECAM 23.450S: Milk Frothing Issues, New Milk Container (Catalog No. 706-UC-2867) 20170208_080407.jpg (3.76 MB) You must be logged in to download this attachment.
    • Delonghi ECAM 23.450S: Milk Frothing Issues, New Milk Container (Catalog No. 706-UC-2867) 20170208_080400.jpg (4.18 MB) You must be logged in to download this attachment.
    • Delonghi ECAM 23.450S: Milk Frothing Issues, New Milk Container (Catalog No. 706-UC-2867) 20170208_080218.jpg (4.32 MB) You must be logged in to download this attachment.
    • Delonghi ECAM 23.450S: Milk Frothing Issues, New Milk Container (Catalog No. 706-UC-2867) 20170208_080338.jpg (1.38 MB) You must be logged in to download this attachment.
    • Delonghi ECAM 23.450S: Milk Frothing Issues, New Milk Container (Catalog No. 706-UC-2867) 20170208_080253.jpg (1.1 MB) You must be logged in to download this attachment.
  • #2 16261785
    mamkonto
    Help: 14
    Rate: 108
    Once in the age of saeco, the solenoid valve was completely clogged. I took it apart from small parts inside, literally a cork seal. steam supply was blocked too (tube)
    There, the solenoid was undressed, although it was almost invisible it was easily unscrewed.
    Disassemble the coil and carefully look at the pin where it is twisted and try to disassemble.
  • #3 16263267
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3337
    michal250490 wrote:
    ... after humming, a loud humming noise is heard and the flow in the direction in which the nozzle is normally located is minimal. Is it possible that the vacuum is too low to draw milk from the container?
    It should not be humming, it should make a "pop" and that's it ... Loud work indicates the pollution of the flip and more precisely its interior.
    At the beginning I advised you to descale
    Kawa i Naprawa - Serwis AGD
  • #4 16263588
    michal250490
    I ordered a new solenoid valve, waiting for delivery. The question is where is the second one located? I can't locate it. Can anyone briefly describe how this milk frothing system works in the sense of how and when each valve is actuated?
  • #5 16263609
    mamkonto
    Help: 14
    Rate: 108
    Assembly drawing sent to PW.
  • #6 16263858
    nioop
    Help: 503
    Rate: 3337
    But for you, I see one solenoid valve ...
    In DeLonghi, sometimes even despite the same model, there are different solutions, just different solutions were used in the course of production.
    Please, take the water tank out and a sticker with a long number behind it. I'm interested in the number for the first space. After him, I can check exactly what and how "sits" with the Lord in the device.
    Please consult before ordering parts for Delonghi. As I mentioned one model several different parts. Heaters, for example, come with different diameters of the inlet pipe.
    By blocking the damaged / contaminated solenoid valve, the steam temperature increases, which usually results in slight deformation of the foamer adapter.
    Therefore, the probability of sucking in the left air / increasing the patency of the adapter increases dramatically. Therefore, it is also recommended to replace the adapter.
    Naturally, this depends on the length of attempts to check the frother, the longer the probability of damage to the adapter increases.
  • #7 16263865
    michal250490
    Hello, thank you for your interest in the topic.
    I give the number 215095.
  • #8 16263885
    nioop
    Help: 503
    Rate: 3337
    One solenoid valve is catalog number 5213218381.
    And that you do DIY in the express machine, maybe the service will be useful?
    • ST1526.pdf (6.34 MB) You must be logged in to download this attachment.
  • #9 16263904
    michal250490
    Great, that's what I meant, step by step described how the full flow in the machine looks like. Thanks a lot!
    Well, I hurried up a bit because I ordered 5213218421. Will it not fit?
  • #10 16263920
    nioop
    Help: 503
    Rate: 3337
    According to the catalog, they match:
    -5213218381
    -5213214011
    What you ordered - It's hard to say, it definitely has a coil turned away, it is not a problem, you can twist it or something, I really do not know.
    It is present in the ECAM 23.450.S EX model: 3.
    And as I mentioned, the same model only the "EX: 3" ending and please look how it looks inside
  • Testing replacement solenoid valve 5213218381
    #11 16265066
    michal250490
    -5213218381
    -5213214011
    I ordered the solenoid valve 5213218381 today, it will probably take place on Monday, I will connect and test, I hope that the adapter with the nozzle is in good working order and I will not have to replace it.
    I have one more question, do you have a detailed electrical diagram of the PCB?
  • #12 16267456
    nioop
    Help: 503
    Rate: 3337
    Oh no, the manufacturer does not disclose such things even to authorized services.
    The manufacturer prohibits all repairs to electronics, only the replacement of modules, hence he urgently guards such things :)
  • Persistent frothing fault despite valve replacement and descaling
    #13 16276307
    michal250490
    Hello again, so I replaced the solenoid valve, but the problem persisted. In addition, after replacing the solenoid valve, the message "Descaling!" Appeared on the display. I attach a video from the operation of the device after replacing the valve. Is it necessary to replace the nozzle adapter?
    I bought a descaling agent and carried out automatic descaling in accordance with the manufacturer's instructions. The effect is the same. So what else may be wrong here:
    1) The milk container is new
    2) Solenoid valve replaced
    3) Descaled coffee machine
    The adapter remains, unless something more?
    • 20170213_185853.mp4 (94.32 MB) You must be logged in to download this attachment.
  • #14 16277452
    BRum
    Help: 42
    Rate: 388
    In 3/4 cases, the decalibrated hole in the adapter is the reason for not sucking in milk. A typical Venturi tube, changing the flow rate creates a vacuum and, as a result, sucking in milk. If heated milk, not foamed, then the problem lies in the lack of air suction.
    Foaming is based on mixing milk with air. The problem should disappear after replacement.
  • #15 16277502
    michal250490
    Ok, as you can see in the video, it doesn't suck milk at all, sometimes the level of the tube will rise, but it will fall soon. Rather, it blows in the milk instead of sucking, and the steam itself flies instead of the frothed milk.
    I hope that I only need to replace the adapter, because I'm running out of ideas. As mentioned above @nioop my espresso model has one solenoid valve and I replaced it yesterday. Today I ordered the adapter, we'll see if replacing it will help. (https://north.pl/karta/7313244781-zlacze-pojemnika-na-mleko-de-longhi---kenwood,708-RG-1668.html).
    I read somewhere else about the replacement of the steam heater. However, probably from what I see in my model of the espresso machine there is only one heater.
    Best regards and thank you for your interest in the topic.
  • Milk system blows steam instead of frothing properly
    #16 16282974
    michal250490
    Welcome back,
    The adapter has been replaced, however, frothing milk does not work as it should. When the milk container is connected to the nozzle, the effect is the same. It does not suck milk and blows into the glass with steam. However, when I press the container firmly to the nozzle and tilt it up (and hold it anyway), it sucks the milk, but it is more like spitting with this milk and it does not look foamy, but rather heated. I don't know what to do anymore, because from the beginning of my fun with repair I bought first a lost milk container, then a solenoid valve, and now an adapter. So due to the fact that I replaced the adapter and the milk container, it should not be a problem with tightness. I am asking for some advice because I have no idea what to do.
  • #17 19097935
    nal3995
    hi, i have the exact same problem as you, which is she doesn't suck milk. Have you found the solution?
  • #18 19100878
    1lele
    Rate: 8
    nal3995 wrote:
    hello i have exactly the same problem as you, which is she doesn't suck milk. Have you found the solution?
    Replace the 2 green O-rings on the outlet where we press the milk container
  • Repeated clutch failures likely caused by steam pressure damage
    #19 19724348
    piga3
    Welcome gentlemen,
    Let me refresh the topic as it seems unsolved. Hope somebody help me. I have a problem with milk frothing with ECAM 23.450B Ex: 3. I probably replaced the clutches with 10 pieces within a dozen or so months ... The course is always as follows: after replacing the clutch, the machine works great for about 1 month, making about 5 milk coffees a day, and then the nozzle / orifice inside the clutch is damaged, manifested by clogging clutch with its insides (pieces of plastic, like pieces of felt). After cleaning / unplugging the clutch, the machine makes foam, but unfortunately it is worse, and probably for 2 weeks. After these approx. 6 weeks, the clutch should be replaced. The parts store does not accept the complaint, claiming that the machine is not properly used (not cleaned, not descaled), which is obviously not true. As a precaution (so as not to block the clutch with a stone), with each descaling, I disconnect the hose from the foamer and descale the coffee machine without the clutch. What, in your opinion, may be the cause of such frequent failure of clutches? Let me mention that I see no faults in the operation of the solenoid valves - they are clean and electrically functional. In my opinion, these clutches are simply faulty / weak and the pressure of hot steam damages them ... Well, unless I'm wrong ...
    PS
    I had a bad experience before with a thermal fuse, temperature sensor and a triac that controls a 1000W heater. Simply by cleaning the steam heater directly with a descaler, I rinsed the thermal grease, which caused the heater to overheat, the thermic melt and the triac was damaged. After replacing the above-mentioned everything is back to normal.
    Besides frothing milk ...
    Best regards and thank you in advance for your help.
The discussion revolves around milk frothing issues with the DeLonghi ECAM 23.450S espresso machine. The user reports that after acquiring a new milk container (Catalog No. 706-UC-2867), the machine fails to froth milk, only producing steam and water. Various troubleshooting steps are suggested, including checking the solenoid valve for clogs, descaling the machine, and ensuring proper assembly of components. Users recommend replacing the solenoid valve and the nozzle adapter, as well as inspecting O-rings for leaks. Despite these efforts, the user continues to experience problems, indicating potential issues with the adapter or internal components. The conversation highlights the complexity of the frothing system and the need for precise parts matching in repairs.
