[Solved] Delonghi ESAM 3500S - Water Accumulation in Coffee Grounds Container Issue
pavelG 46332 7
  • #1 16437714
    pavelG
    Rate: 9
    I have a De’Longhi ESAM 3500S. Water has appeared in the container where the coffee grounds – those little discs – collect.
    robsons10
    Help: 73
    Rate: 401
    Hello. As above, specify where it flows when the door is open. I put a seal on the distributor or distributor piston seal.
  • #4 16691380
    pavelG
    Rate: 9
    rather technically impossible to see where it leaks in this model with the door open I replaced the seal on the piston and then leaks
  • #6 16709002
    pavelG
    Rate: 9
    [Film: c49423ce4f] https://filmy.elektroda.pl/64_1505854066.mp4 [/ film: c49423ce4f]
    Added after 7 [minutes]:
    As you can see in the video, the water in the upper part of the brewing chamber and with coffee grounds is pushed into the grounds container. How to fix it ?
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3339
    As for mine, if the coffee rings are not too thin, the problem lies on the venting side.
    There are two outputs:
    - heater replacement, which is associated with high costs
    - regeneration of the generator / piston, lower costs but much more work. (dismantle, clean, replace the seals, apply approved grease)
    Kawa i Naprawa - Serwis AGD
  • #8 17276209
    pavelG
    Rate: 9
    sold was not worth repairing
The discussion revolves around a water accumulation issue in the coffee grounds container of the Delonghi ESAM 3500S. Users suggest visually inspecting the source of the leak and recommend checking the seals on the distributor or piston. One user notes the difficulty in identifying leaks with the door open and mentions having replaced the piston seal without resolving the issue. A video is shared demonstrating water in the brewing chamber pushing into the grounds container. Solutions proposed include addressing venting issues, which may involve either costly heater replacement or a more labor-intensive regeneration of the piston, including cleaning and seal replacement.
