DeLonghi ECAM 350.55 B - Milk Frother Not Working After Descaling, Tried Milk Clean & Cleaning
terre 38880 6
  • #1 16865445
    terre
    Rate: 10
    The problem appeared after a month of use and after the descaling cycle. The coffee maker has stopped foaming milk. The tube shows that it can not quite finish how to draw milk from the container and, unfortunately, flies a couple or spits with water. I tried to calend the second time, unfortunately it did not help. I will add that after every event everything was cleaned and rinsed as in the instructions. Allegro I bought a special Milk Clean - a cleaning agent for milk sludge and it also did not help. After the forums I see that there is a problem with the milk frother in various models and it is quite an emergency. The rest work without a hitch. Maybe someone has any ideas for healing the foamer or knows what has been specifically mentioned in the machine so that everything works again ????
    I know that I have a two-year warranty but I will give the warranty for a warranty but after the new year, because I also see that the service keeps the machine in repairing a month of time.
  • #2 16866597
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3337
    Automatic foaming in DeLonghi coffee makers is quite an emergency.
    There are no fixed weaknesses. Any element a is a little may be damaged.
    However, if it has a guarantee - why expose yourself to the cost and loss of warranty?
    Kawa i Naprawa - Serwis AGD
  • #3 16866664
    terre
    Rate: 10
    I do not intend to combine anything. There is a guarantee and I will give you the express after the new year. In the past I thought that goat is some shit like Np orings on the nozzle what a war milk container is.
  • #4 16893969
    terre
    Rate: 10
    And someone already has a coffee maker after foamer repair ???? Can someone write what was the reason for not milk? ??????
  • #5 16897522
    nioop
    Help: 503
    Rate: 3337
    In my experience, the elements that break down and cause non-foaming:
    Solenoid valve v3
    Solenoid valve v2
    Heater
    Thermal protection
    Foamer clutch
    Cup
    As you can see it is a complete foam system, on line is a guessing what could have gone wrong. You have to undress and check the whole layout of another simpler method, unfortunately there is no.
  • #6 16959593
    terre
    Rate: 10
    Unfortunately, everyone has a disastrous approach to the client and of course everything is wrong and it is his fault.
    Despite the fact that the water is filtered through 3 filters, in addition I have a filter in the water tank in the stonework I made the middle which was included in the set, and so my fault that apparently I did wrong with stonework.
    This is one big misunderstanding, everyone will sell the device and if something happens or breaks down and this is on warranty, it is the enemy number 1 !!!!
  • #7 17053709
    terre
    Rate: 10
    I picked up the coffee maker a month ago with a warranty repair and a snap which works :) so +
    But the blame, of course, as it usually is and happens - the USER. Why, so I have the reverse osmosis filter installed in the house, the water was always poured into the espresso machine filtered + additionally I had a filter installed in the coffee machine in the water tank. You stated that they already had such cases and filtered water from the tap clogs the filter in the LoL coffee machine. As far as I know, the filters are for them to catch the difference.
    But ok. The Lord said that the finishing is a water pump, acted, but they already exchanged it on the occasion because they suspected that in about 2 weeks would be broken. And here suddenly another explanation for the problem namely the Lord suggested that the pump was too small for pressure and that was why it was not enough for the milk to foam :)
    And at the end of this information at the DeLonghi branch in Krakow.
The DeLonghi ECAM 350.55 B coffee maker's milk frother malfunctioned after a month of use and following a descaling cycle. Users reported issues with the frother not foaming milk, with symptoms including the frothing tube failing to draw milk properly and spitting water. Despite attempts to clean the system using a specialized Milk Clean agent and following cleaning instructions, the problem persisted. Various users noted that the foaming issue could stem from several components, including solenoid valves, the heater, thermal protection, and the foamer clutch. Some users expressed frustration with customer service and warranty processes, while others shared experiences of successful repairs, indicating that the water filtration system might contribute to the problem. The warranty remains a viable option for users facing similar issues.
