VW Polo III 6n2 - I am looking for a description of fuse symbols
mgrokrutny 150894 5
  • #1 16434028
    mgrokrutny
    Rate: 31
    I have a note with fuse symbols. I am asking for help in assigning names to symbols.
    Thanks
    VW Polo III 6n2 - I am looking for a description of fuse symbols VW Polo III 6n2 - I am looking for a description of fuse symbols
  • #3 16434759
    mgrokrutny
    Rate: 31
    You gave the link to the 6o Polo box, I mean 6n2 with 51 fuses. I was looking, I can not find.
  • #4 16436659
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1423
    Maybe take a look at it
    1 - 10.0 A - No information available
    2 - 5.0 A - License plate light (s)
    3 - 10.0 A - No information available
    4 - 5.0 A - Side light, left
    5 - 5.0 A - Side light, right
    6 - 15.0 A - Wash / wipe, rear
    7 - 7.0 A - Direction indicators
    8 - 5.0 A - ABS EDS ESP
    9 - 5.0 A - Headlamp alignment
    10 - 7.0 A - Internal light (s)
    11 - 5.0 A - Diagnostic system, Air conditioning
    12 - 10.0 A - Main beam, right
    13 - 10.0 A - Main beam, left
    14 - 10.0 A - Warning lights of danger, Alarm system
    15 - 10.0 A - Brake light (s)
    16 - 5.0 A - Ignition switch, S.
    17 - Not used
    18 - 5.0 A - Heated mirror (s)
    19 - 15.0 A - Sound signal
    20 - 10.0 A - Telephone
    21 - 5.0 A - Automatic transmission
    22 - 15.0 A - Alarm signal
    23 - 5.0 A - Exhaust Gas Recirculation (EGR) Auxiliary heater, Glow plug relay
    24 - 5.0 A - Switching off brake lights
    25 - 5.0 A - Selector handle lamp (s)
    26 - 7.0 A - Air conditioning, Central locking, Windows, GPS
    27 - 5.0 A - Instruments
    28 - 5.0 A - Speed sensor, Immobilizer
    29 - 7.0 A - Reversing lamp (s)
    30 - 5.0 A - Evaporative treatment control system, Exhaust Gas Recirculation (EGR)
    31 - 5.0 A - Fuel system control assembly
    32 - 5.0 A - Fuel cutoff
    33 - 10.0 A - Locking the handle of the automatic transmission selector
    34 - 10.0 A - Ignition transformer
    35 - 25.0 A - Sliding roof
    36 - 15.0 A - Engine control unit
    37 - 15.0 A - Engine control unit
    38 - 25.0 A - Glass, left
    39 - 25.0 A - Glass, right
    40 - 15.0 A - Fuel pump
    41 - 15.0 A - Central locking, Anti-theft system
    42 - 15.0 A - GPS radio
    43 - 15.0 A - Fog light (s)
    44 - 15.0 A - Left dipped beam
    45 - 15.0 A - Right dipped beam
    46 - 15.0 A - Cigarette lighter
    47 - 20.0 A - Headlamp washers
    48 - 20.0 A - Heated rear window
    49 - 25.0 A - Blower
    50 - 15.0 A - Washing / wiping system
  • #5 16442306
    mgrokrutny
    Rate: 31
    Thank you :) You're a Good Man :)
  • #6 17527112
    bungar
    Rate: 33
    Sorry to refresh, but I can't find the fuse from the signal not turning off the lights on the Polo 6n2. I mean the signal that appeared after removing the key from the ignition switch, if you forgot to turn off the lights. I will be grateful for your help.
