Touran 2008 Fuse Guide: Troubleshooting User Messages and Electrical Issues - Join the Discussion!
touran 1955 110858 5
  • #1 7985411
    touran 1955
    I am looking for a description of VW Touran 2008 fuses. Thank you in advance.
  • #2 8417527
    GASIOR997
    Rate: 14
    Fuse box in passenger compartment
    1 - 5.0 A Automatic anti-dazzle rear-view mirror
    2 - 5.0 A Trailer detection control unit
    3 - 5.0 A Air conditioning high pressure sensor
    4 - 5.0 A Brake pedal switch Clutch pedal switch
    5 - 5.0 A Heated Seat (a), Front Fuel Pump a (FSi only)
    6 Not used
    7 - 5.0 A Heated Seat Control
    8 - 5.0 A Heated washing machine nozzles
    9 - 5.0 A Airbag control unit
    10 - 5.0 A Fuse phone control unit 11 - 10.0 A Steering control unit with assist
    12 - 5.0 A Tiptronic switch Selector handle switch
    13 - 10.0 A Headlamp range adjustment Fuse 14 - 5.0 A TCS / ESP button
    15 - 10.0 A Reversing light (s) Diagnostic connector
    16 - 5.0 A Data transmission Fuse 17 Not used
    18 Not used
    19 Not used
    20 - 5.0 A Parking assist control module
    21 - 5.0 A Tiptronic switch Selector handle switch
    22 - 5.0 A Receiver for additional remote control
    23 - 10.0 A Brake light switch
    24 - 10.0 A Heater system Light switch On board diagnostics
    25 Not used
    26 - 10.0 A Engine control unit
    27 Not used Fuse 28 - 5.0 A Fog light (s)
    29 - 15.0 A Rear Wiper Fuse 30 - 25.0 A Control unit for power supply to the on-board system
    31 - 15.0 A Auxiliary heater relay
    32 - 15.0 A Pump for windshield washer
    33 Not used
    34 Not used
    35 - 40.0 A Blower Fuse 36 Not used
    37 Not used
    38 Not used
    39 Not used
    40 - 20.0 A Trailer detection control unit
    41 - 20.0 A Socket for trailer
    42 - 15.0 A 12V socket, rear
    43 - 15.0 A Fuel pump relay Fuel pump a
    44 - 5.0 A Indoor monitoring Alarm signal Vehicle inclination transmitter 45 - 5.0 A Antenna amplifier
    46 - 7.0 A On-board power supply control unit
    47 - 25.0 A Cigarette lighter, front Cigarette lighter, rear
    48 - 20.0 A Relay for headlight washer
    49 - 10.0 A Driver's door control module Front passenger's door control module
    50 - 30.0 A Heated front seat (a)
    51 - 20.0 A Sliding roof control module
    52 - 25.0 A Auxiliary heater relay
    53 - 25.0 A Electric components for amenities
    54 - 5.0 A ECU, automatic transmission
    55 Not used
    56 - 40.0 A Blower or not used
    57 Not used
    58 Not used
    Fuse and relay box in the engine compartment
    1 - 30.0 A ABS with EDL control unit
    2 - 30.0 A ABS with EDL control unit
    3 - 25.0 A Passenger's side windshield wiper motor
    4 - 5.0 A On board power supply control unit
    5 - 20.0 A Audible signal
    6 Not used
    7 Not used
    8 - 10.0 A Motor for regulating the valve on the intake manifold Cooling fan
    9 - 10.0 A Fuel pump relay Glow plugs Glow plug control unit
    10 - 10.0 A Exhaust gas recirculation Solenoid valve with turbo regulation
    11 - 30.0 A diesel injection ECU
    12 - 15.0 A Lambda Probe
    13 - 5.0 A ECU, automatic gearbox
    14 Not used
    15 - 25.0 A Starter
    16 - 30.0 A Terminal voltage supply relay 15
    17 - 10.0 A Insert for instrument panel
    18 - 15.0 A Steering column electronics control unit
    19 - 15.0 A Radio
    20 - 10.0 A Telephone
    21 Not used
    22 Not used
    23 - 10.0 A Distance adjustment control unit
    24 - 10.0 A Data transmission
    25 Not used
    26 - 10.0 A Diesel fuel injection ECU terminal 30 voltage supply relay
    27 Not used
    28 - 10.0 A ECU, automatic gearbox Multifunction switch
    29 - 20.0 A Crankcase heater
    30 - 10.0 A Injectors Glow plug relay
    31 - 25.0 A Driver's side windshield wiper motor
    32 - 5.0 A Heater control assembly
    33 Not used
    34 Not used
    35 Not used
    36 Not used
    37 Not used
    38 - 20.0 A Fuse box in passenger compartment
    39 - 5.0 A Oil level sensor Oil temperature sensor Instrument panel insert
    40 - 10.0 A Spotlight range adjustment
    41 - 20.0 A Vacuum pump for brake
    42 - 5.0 A Mass air flow sensor
    43 Not used
    44 Not used
    45 Not used
    46 Not used
    47 - 40.0 A Control unit for power supply to the on-board system
    48 - 40.0 A Terminal voltage supply relay 15
    49 - 50.0 A Control unit for power supply to the on-board system
    50 - 10.0 A Amplifier
    51 - 40.0 A Glow plug control unit
    52 Not used
    53 - 50.0 A Door Control Module (DCM) Central locking
    54 Not used
    R1 Terminal voltage supply relay
    R2 Terminal voltage supply relay
    R3 Not used
    R4 Terminal voltage supply relay
    • touran_2006_elektryka.pdf (210.3 KB) You must be logged in to download this attachment.
  • #3 17581440
    grzesio2507
    Help: 10
    Rate: 50
    I made a print version, it may be useful to someone :) better to read :) .
    Can be carried in the car.
    Greetings!
    • Bezpieczniki touran.docx (77.47 KB) You must be logged in to download this attachment.
  • #4 18147432
    buska1982
    Thanks for the schedule
  • #5 19078105
    Adam20028
    Rate: 12
    And which fuse is responsible for lighting the interior?
  • #6 19492660
    Touranunited28
    Rate: 13
    Hello, I have the same problem, I put on the LED bulbs, it was ok, they went out by themselves and I got a message on the computer about the error of a burnt bulb, which fuse is responsible for this, I have no idea, please help
