Removing MAN TGL 12-240 Driver's Seat: Key Issues & Seat Removal Process
piotr.interex 15021 2
  • #1 16439389
    piotr.interex
    Hello, asking how to remove the Man tgl 12-240 driver's seat to get inside, not all the keys work and I can not remove the seat, anyone help?
  • #2 16441343
    darfur5
    Help: 267
    Rate: 1715
    There are several solutions depending on the model, whether it is Grammer or Isri. Look under the seat (from the steering wheel side) there should be a lever and it is caught on a notch in the seat base. You have to unplug it from this tooth by lifting the lever up and that it won't give up easily, it's best to help yourself with a screwdriver. In another model, the security features are in the rail on which the seat moves, then you need to move the seat forward as much as possible, prepare two thin screwdrivers and find holes on the sides of the seat, locate the spring in them (steel rod) that blocks the seat, push it down and at the same time remove the seat. Note - the spring can be on both sides of the seat and sometimes only on the left. Otherwise, a plastic lever in the same color as the other operating buttons of the chair is mounted in the front seat, it must be pulled up and the seat removed.
  • #3 16441602
    piotr.interex
    Hello, thanks for the answer, the hole is on the left I tried, without effect, the keys from the tilt cracked all rattled is the gamer best to wring it all out and on the table it will be the best but I will try to write what I did, greetings.
