LG 42LD650-ZC TV: All 3 HDMI Outputs Stopped Working, Signal Issues, Firmware v03.21.03 Update
plaszczka 5160 10
Why do all HDMI inputs on my LG 42LD650-ZC show “connecting” and then “no signal” even though AV and USB still work?
First check the output resolution of the connected device; one user had the same symptom and fixed it by changing a DVB-T decoder from 1080p to 1080i [#16441756] If the HDMI problem is intermittent on all ports and comes and goes by itself, another reply says this model can suffer from a typical cold solder joint on the processor, which points to a hardware/service repair [#16616091]
  • #1 16440864
    plaszczka
    Hello to all forum members, since yesterday I have a problem with my LG 42LD650-ZC TV.
    Suddenly all three HDMI outputs stopped working, it still says "connecting" and "no signal".
    I did some research on this forum and, trying to do something myself, installed the latest firmware, version v03.21.03, but it did not help and the problem still persists. The TV connected with the AV connector shows the image normally (but we know about the quality), the USB movie is also displayed correctly, generally the TV works but does not transmit the signal via HDMI.
    Unfortunately, the equipment is no longer under warranty, it is about 5 years old (this is how much has passed from the date of purchase). What do you propose to take? Is it profitable to send it to the LG service, can you replace something yourself, some module responsible for HDMI, is it a larger connected system and the costs will be huge? Help!
  • #2 16441111
    LeDy
    Help: 1990
    Rate: 2937
    And with the remote control (INPUT) you change the inputs?
  • #3 16441135
    plaszczka
    Yes, I change, inputs are detected correctly along with descriptions - using the remote control and on the side panel of the TV.
  • #4 16441155
    LeDy
    Help: 1990
    Rate: 2937
    How are they detected? They should detect the signal applied to one of them, unless the cable is damaged or what you are connecting?
  • #5 16441182
    plaszczka
    Sorry for the error, the TV detects that the devices (decoder or laptop) are connected to it and in the selection panel "highlights" these devices and you can select them when I disconnect the cables, the backlight naturally disappears and you cannot select the device. I checked on 4 different HDMIs that normally work plugged elsewhere and have successfully dealt with the TV before :) The point is that despite the fact that the connection is visible and the devices are torn off, the screen (after selecting a specific HDMI in the panel) displays only "connection in progress" and after a while "no signal". This is what it looks like.
  • #6 16441756
    LeDy
    Help: 1990
    Rate: 2937
    See what resolution the connected device has. Recently I had a DVB-T decoder connected via HDMI and the description was identical because it was set to 1080p instead of 1080i
    Good reception when set to 1080i.
  • #7 16442538
    plaszczka
    Look ... I'm coming home from work now, I turn on the TV, check HDMI ... it works :) On its own after two days. Strange thing.
  • #8 16442723
    maksar
    Help: 177
    Rate: 1030
    plaszczka wrote:
    Strange thing.
    Yeah, read about LG and HDMI inputs.
  • #9 16442900
    LeDy
    Help: 1990
    Rate: 2937
    And take him now prove that prompting didn't help him a ..... ????????? It has become a MIRACLE.
  • #10 16443198
    plaszczka
    Yeah and I ran out ... it works, it works, it starts blinking, it goes out ... it works and so on and on, I even replaced the decoder in the digital polsata with another one because I thought that maybe that's what it was about but no ... I checked so many things that I'm sure it's a problem with hdmi, what do you think next?
  • #11 16616091
    mkkomp
    Probably a cold February on the processor, a typical fault of this model. Ask the user Service 1 Link
The user reports that their LG 42LD650-ZC TV has experienced a failure of all three HDMI outputs, displaying "connecting" and "no signal" messages despite the devices being detected. They attempted to resolve the issue by updating the firmware to version v03.21.03, but the problem persisted. The TV functions normally with AV and USB connections. Forum members suggested checking the resolution settings of connected devices and confirmed that the HDMI inputs were recognized. After a couple of days, the HDMI outputs began working again intermittently, leading to speculation about potential hardware issues, including a common fault related to the processor in this model.
