LG 37LD450-ZA TV - No Sound, Headset Connected Error, Tried Factory Reset & SCART Removal
l0nger 3207 6
  • #1 16742914
    l0nger
    I am asking about the cause of the problem in the lack of sound in this TV model.
    Despite the lack of any speakers / headphones etc. connected to the Mini-Jack socket, the television informs that "the headset has been connected" and does not emit sound. Earlier I used these audio sets for the jack, but I stopped in favor of the recently bought speaker which was connected to this TV model with the SCART connector. I noticed the problem when switching from one audio system to another. I tried restoring factory settings and disconnecting any audio devices from the SCART connector and from Jack - both unsuccessfully. I make an inquiry here - on the electrode. Servicemen and professionals - help! :(
  • #2 16742947
    BILGO
    Help: 393
    Rate: 725
    The micro contact in the headphone jack may be damaged ;) Pay attention to this
  • #3 16742956
    l0nger
    When using headphones through the headphone jack, the sound is emitted - not unplugged. So I understand that this micro contact can affect this?
    In addition, would repair / replacement of such a headphone jack cost a lot and can it be done at home or better through the service?
    BILGO
    Help: 393
    Rate: 725
    There is a micro contact somewhere that gives information to uP whether headphones are connected or not. If the message is still displayed, this is something ;) You have to check it out. If you don't know it, send it to the service ;)
  • #5 16742997
    l0nger
    Okay, thank you very much for your reply, it will be checked and at best exchanged by a service representative :)
    BILGO
    Help: 393
    Rate: 725
    This is not 100% certain ;) But the service technician will definitely handle it
  • #7 16776187
    l0nger
    The problem is solved - the problem is eliminated by sending the device to the service - the guest replaced the Jack socket and everything flashes beautifully.
    Thank you for all the help - topic closed :)
The LG 37LD450-ZA TV experienced a sound issue where it falsely indicated that a headset was connected, despite no audio devices being plugged in. The problem arose after switching from headphones to a speaker connected via SCART. Users suggested that a damaged micro contact in the headphone jack could be the cause, which might misinform the TV's microcontroller about the connection status. After troubleshooting, including a factory reset and disconnecting devices, the issue was resolved by sending the TV to a service technician who replaced the faulty headphone jack.
