Restoring Mercedes W124 CE300 Coupe: How to Master Belt Feeders & Troubleshoot Control Issues
Majeran123 6321 1
  • #1 16441314
    Majeran123
    Rate: 78
    Hello, I am resuscitating such a Mercedes. I cannot master the feeders.
    I open the car, open the door (I checked the limit switches, upper mass,
    middle +, lower mass, pressing the middle one snaps a relay in the board.
    mass comes to the module) I make a jumper on the ankle from the armchair, close the door,
    I turn on the ignition. And the feeder just vibrates. Motors working, I checked on
    short. When I disassemble the module and short circuit, the relay comes out, pressing the other retracts
    out.
    My guess is the control is missing.
    I do not know which pin to give the mass and when it should turn on.
    in the module cube there is a constant mass, a constant plus and plus after ignition.
    I need a diagram of how to connect this module.
    I had one found somewhere on the internet supposedly from 124 but unfortunately it didn't match.
    • Restoring Mercedes W124 CE300 Coupe: How to Master Belt Feeders & Troubleshoot Control Issues DSC_0032.JPG (2.37 MB) You must be logged in to download this attachment.
  • Adjusting rail limit switches fixed belt feeder control
    #2 16443379
    Majeran123
    Rate: 78
    Hello gentlemen. I dealt with this topic, it was enough to adjust the limit switches on the rail. However, before I got to that, I went over the installation.
    Please, here is a diagram of how it is connected ON THE PASSENGER SIDE.
    Maybe someday it will be useful to someone. :)
    On the second one, I didn't have to research, so the colors may be different :)
