[Solved] W124 Mercedes - Installation of the central locking controller.
Matik208 15024 9
How do I connect an aftermarket central locking controller in a Mercedes W124 with pneumatic central locking?
For a post-1992 W124, the old pneumatic wiring diagrams do not apply, because the car has an infrared receiver/module near the central locking pump under the rear seat that decodes the signal and controls the pump directly [#17218051] There are no door contactors in this version, so the locking cannot be triggered through the front door or tailgate key switch like in older cars [#17218051] One suggested hookup point was the central locking button on the center console, if the car has one [#17219862] In the end, the practical solution reported in the thread was to connect the controller directly to the pump [#17257261]
  • #1 17215523
    Matik208
    Rate: 30
    Hello, I have a question about how to connect the central locking controller. The wiring diagram from the installation manual does not pass the test (pneumatic option connection). I heard that it is done with two relays, but I don't know the details. I would ask for help. Mercedes W124
    Moderated By CameR:
    Reg. 3.1.16 Do not post questions for which the answer can be easily found on the internet or on the electrod forum.
  • Central locking relay and pump under rear seat
    #2 17215668
    darekwko
    Rate: 11
    I have a w124 and the locking of the central locking is pneumatic. As far as I know, the driver is under vacuum. I would check if it is operational, check the pump vacum. In the trim of the car everything works very well as long as the shortcuts are properly fixed then they come out sideways. If the vacuum pump works badly, there should be problems with starting and shutting down the engine.
    Added after 16 [minutes]:
    Sorry, but I wrote a little nonsense, I checked it in the car and my memory is failing me a bit. (my star doesn't break down so often :D ) The controller is pneumatically controlled, but it does not take anything from the pump vacuum, but there is everything (the switchboard including the relay and the pump) under the back seat. If there are fuses in the switchboard and when they blow, it is not the trunk lighting, but more often the relay sits, which is hard to check, less often the pump. But I do not remember it well, it was described well in the forum w124. For me, I can't hurt my star and replace parts and don't cut shortcuts.
  • #3 17216330
    Matik208
    Rate: 30
    The point is that there is no original remote control and I want to add a control panel with remotes, I don't want to rework anything.
  • #4 17216348
    CameR
    Moderator of Vehicle Security
    Help: 1141
    Rate: 3274
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • Need for additional relays in pneumatic central locking control
    #5 17216737
    Matik208
    Rate: 30
    when I connect according to the diagram, the connection of the pneumatic version is not controlled by the pump, so I asked if additional relays should be installed.
    CameR wrote:
    Added after 11 [minutes]:
    sometimes it will control me, but the control cables are heating ... (from the added switchboard)
    CameR wrote:
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3631
    No data for the car again - because "124" is not everything!
    From the note that there is no original remote (and not the "original" one), I conclude that this is a post-92 version.
    So the car has receivers for the infrared signal emitted by the key, the signal is amplified in the receiver and it reaches the InfraRed module located near the pump under the rear seat. There, the signal is decoded and controls the central locking pump.
    The pump is different than in previous years: there is no round plug with yellow, blue and green wires because there are no contactors in the door. So it is not possible to activate the central locking by turning the key in the front door or the tailgate. So the diagrams to which you are referring are "crush .. to break up" in this case.
  • #7 17219647
    Matik208
    Rate: 30
    Yes you are right :) It is exactly like you are saying just asking how to connect it now :)
  • #8 17219862
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3631
    This is years ago, but as far as my memory is correct, there is a possibility of connecting to the central locking button on the center console.
  • #9 17219987
    Matik208
    Rate: 30
    unfortunately there is no button on the console :(
  • #10 17257261
    Matik208
    Rate: 30
    I connected directly to the pump and I close the topic.
The discussion revolves around the installation of a central locking controller for a W124 Mercedes, specifically addressing issues with connecting the pneumatic version of the system. The user seeks guidance on wiring the controller, as the provided connection diagram is ineffective. Responses indicate that the central locking system operates via a vacuum pump located under the rear seat, and that the absence of an original remote complicates the installation. It is noted that the post-92 models have a different pump configuration, lacking the traditional wiring setup. Suggestions include connecting directly to the pump and exploring the possibility of using relays for control. Ultimately, the user resolved the issue by connecting directly to the pump.
