Seeking Schematics or Guidance: Fixing Mercedes E220 96r. 2.2 D Reverse Light
szalek2112 14872 14
How do I troubleshoot and fix the reverse lights on a 1996 Mercedes E220 2.2 diesel automatic?
Check the bulbs and fuses first, because on Mercedes a fuse can look intact and still be faulty, so replacing the suspect fuse is worth trying [#10304631] [#10304898] On this automatic, the reversing lamps E18 and E20 are supplied by the light module, and the reverse signal comes from the S28 switch, which is part of the multisection switch 249 [#10339260] So if the bulbs and fuses are good, the likely fault is in the reverse-switch/selector-switch circuit rather than a gearbox-mounted switch [#10339260]
  • #1 10304520
    szalek2112
    Hello, does anyone have schematics or would tell me how to fix backlights. I checked the fuses but I do not know if it works well. I am asking for help that this is an automatic chest.
  • #2 10304631
    wojtekryba
    Level 32  
    Help: 152
    Rate: 484
    Start with bulbs.
    And if you do not know if you checked the fuses correctly, then sorry,
  • #3 10304898
    SauerMauser
    Help: 26
    Rate: 98
    In Mercedes I have met several times with a situation where the optically efficient fuse was out of order. The exchange has helped. Excluding light bulbs, assuming they are in working order.
    And how to check the fuse, ask your neighbor. :D
  • #4 10307687
    szalek2112
    Thanks for the answer, I will replace the fuses with new ones, I think that it will help because the bulbs are 100% efficient. And one more small question if anyone could send me a fuse scheme, ie which one suits.
  • #6 10308299
    pioart
    Help: 343
    Rate: 1470
    Ktrze safniki sprawdzałeś / w stronie miejscu /?
    To verify fuse nr 4 or 12 / I do not remember the console.
  • #7 10308694
    szalek2112
    I checked the fuses at the steering wheel under the bonnet and under the seat at the back all are fine because I exchanged for new ones. All lights work only reversing light not :( . Motronic you can expand your speech. :D
  • #8 10310224
    szalek2112
    Maybe someone has a schematic of the entire electric car, I would be grateful if I could handle 100%. :D
  • #9 10337328
    szalek2112
    Where this reversing switch is located, because I do not know, I have already dismantled the shift cassette but I do not know how it looks like HELP
    Added after 8 [minutes]: < br />
     Maybe some sensor is on the gearbox ??
  • #10 10337423
    szalek2112
    I was looking and I know what it looks like but I can not find anything like that, I will put pictures and if you could show me where it is :D
    Added after 9 [minutes]: < br />
      Seeking Schematics or Guidance: Fixing Mercedes E220 96r. 2.2 D Reverse Light Seeking Schematics or Guidance: Fixing Mercedes E220 96r. 2.2 D Reverse Light Seeking Schematics or Guidance: Fixing Mercedes E220 96r. 2.2 D Reverse Light
  • #11 10337481
  • #12 10337497
    szalek2112
    So how because I do not understand? At the beginning I wrote that it is an automaton
    Added after 7 [minutes]: < br />
     Help because I do not know what to do anymore
  • #14 10340001
    szalek2112
    Motronic thanks! I handled the case. And again thanks to :D
  • #15 10340005
    Pawel wawa
    Help: 1262
    Rate: 4423
    I have cleaned the subject and I do not want unnecessary comments.
✨ The discussion revolves around troubleshooting the reverse light issue in a 1996 Mercedes E220 2.2 D. The original poster seeks schematics or guidance after checking the fuses, which they believe may not be functioning correctly. Responses suggest starting with bulb checks and replacing potentially faulty fuses, as some users have encountered situations where fuses appeared functional but were not. The poster confirms that all other lights work and expresses a need for a schematic of the vehicle's electrical system. Further inquiries lead to discussions about the location of the reversing switch and its relation to the automatic transmission. A helpful response provides a schematic indicating that the reversing lamps are powered by the light module, with the reverse signal sourced from a specific switch in the multisection switch assembly. The poster successfully resolves the issue with the provided information.
