Manta 5000mAh Power Bank Incomplete Charging - Not Sufficient for Full Phone Charge
Agava 7917 5
  • #1 16446421
    Agava
    Hello, I do not know if it's a good group, if not I ask for a hint where I am supposed to be guided and so I bought a power bank Manta 5000 mAh after charging it I plug it into the phone and it only charges 50% and it's already discharged, is it possible with 5000mAh is not enough for one full charge?
  • #2 16446521
    E8600
    Help: 529
    Rate: 2520
    Very possible because this powerbank has only written that it has 5000mAh and it really has about 1500-2000 probably. Provide a photo or model of this invention. If you have the option, give it as a non-compliance of the product with the description.
  • #3 16446598
    Sniezynka
    Help: 199
    Rate: 841
    I have a Mantle with a capacity of 2850mAh and easily loads the Samsung galaxy phone to full.
    Advertise and that's it.
  • #4 16447051
    Agava
    MPB003 Power Bank 5000 - Manta SA is this model but I have already found on Ceneo opinions that others also have so promotion they wanted to get rid of shit ** and unfortunately I threw the receipt well that cost 20 PLN ? thank you for the answers
  • #5 16448362
    miko1282
    Power Banks have Li-Ion accumulators, their voltage is about 3.7V powerbank is equipped with inverter which raises this voltage to 5v, no converter has 100% efficiency, I have a powerbank of 20,000mAh (3.7v) but it has only 12,700mAh per 5v and this is due to the fact that it charges you to about 50% simply, the producers give how much capacity they have batteries installed in their power banks, and not how much power the bank can give away. greetings
  • #6 16448465
    E8600
    Help: 529
    Rate: 2520
    In part you are right but such a big loss can not just put the li-ion links in this range and so much in the subject (20A x 3.7V = 74W and 12.7A x 5W = 63.5W or efficiency of about 85% au a friend with a manta will probably come out with 30% so it is not an inverter). People are unaware that when they use the phone and simultaneously charge it, it consumes more mAh than it is written on the battery in the phone.
