Sony m4 Aqua Shutdowns Every 30 Seconds and Charging Issues: Battery or Motherboard?
Rob5on 2739 6
  • Asking whether battery or motherboard is faulty
    #1 16564540
    Rob5on
    Hello, as in the topic. I have m4 aqua and after some time the phone started to malfunction. It turns off practically every 30 seconds. And it is not possible to charge. The telephone was in the service, because the socket was broken. After the phone came back to me, these problems started. My question is as follows. Is it a problem with the battery or maybe with the motherboard. I don't want to have it serviced, I want to do it myself, I just don't know what to replace. I am asking for help and thank you in advance :)
  • #2 16564600
    nutergsm
    Help: 1034
    Rate: 1665
    Does it turn off under the charger?
    By yourself, without knowledge and experience, you can only damage the phone more.
  • Battery likely faulty; charger input not powering phone
    #3 16564608
    Rob5on
    It does not turn on at all under the charger. It charges with a 1.5A powerbank and I can see if it gets electricity and does it. But it's discharged all the time, and I don't remember seeing wallpaper in it anymore :D But yes, it also turns off when charging.
    The phone is written off anyway, I use the Z2, and with this I just want to find out if I can do something, if it's not difficult. I don't want it to work, but I'd like to learn a bit and maybe fix it.
  • #4 16564620
    nutergsm
    Help: 1034
    Rate: 1665
    Check if the usb socket is well soldered. I would also replace the battery.
  • #5 16564625
    Rob5on
    The socket is not soldered, it is for tape
    nutergsm
    Help: 1034
    Rate: 1665
    Start with the battery. I would also unplug the usb socket and then check how the phone behaves.
    It's a bit strange that the service gives back the phone with such symptoms, unless the fault arose later, and not when the phone returned from the service.
  • Charging briefly reaches Sony logo then shuts off
    #7 16564652
    Rob5on
    It was a "familiar" service ... The guy didn't do it professionally, after a few days the back began to peel off (it was most likely glued to the adhesive tape), I lost the screw because it was flying inside the housing. He did not give a receipt and did not get cash. We are both negative.
    First, I would like to recharge it a little so that it even turns on. And then I will do as you say. For now, it is charging since the morning and still the message that the battery is low.
    Added after 2 [hours] 43 [minutes]:
    The phone has charged a little. With the socket unplugged, charging also turns off. It flashes on to the word SONY and again.
The discussion revolves around issues with the Sony M4 Aqua, specifically frequent shutdowns every 30 seconds and charging problems. The user reports that the phone does not turn on while charging and remains discharged despite using a power bank. Responses suggest checking the USB socket for proper soldering and replacing the battery as potential solutions. The user indicates that the phone was previously serviced, but the quality of the repair was questionable, leading to the current issues. Further troubleshooting steps include unplugging the USB socket to observe the phone's behavior and ensuring the battery is charged sufficiently before further attempts at repair.
