The candles float in oil 1.8 ADR - replacement of the gasket under the valves
fux10 11511 8
  • #1 16448507
    fux10
    Rate: 9
    Hello everyone. I have a problem, I have noticed recently that the spark plug in my car floats in oil, I know it shouldn't be like that, that's why I immediately started looking for help in the forum. Everything indicates that there is no other way but to replace this gasket. I started reading a bit on the internet and most write that it is a simple procedure and I can do it myself, I have already bought an elring seal and I think I will do it myself, unless you strongly advise against it. Ok to the point. The engine looks like this The candles float in oil 1.8 ADR - replacement of the gasket under the valves and it can be seen from afar that where the cable from candle No. 2 runs, it is wet from oil.
    Up close it looks like this The candles float in oil 1.8 ADR - replacement of the gasket under the valves
    and when I take off the rubber ignition cable (I think that's what it's called) to see the candle, you can't see it at all, it's all covered with oil like in the picture. The candles float in oil 1.8 ADR - replacement of the gasket under the valves The candles float in oil 1.8 ADR - replacement of the gasket under the valves
    I don't know much about cars, but it seems to me that the candle should be dry, here it is not.
    By the way, I noticed that I have a slightly wet engine on the left, this clearly confirms the need to replace the gasket. The candles float in oil 1.8 ADR - replacement of the gasket under the valves
    In view of all this, I have some questions for you. And so:
    1. Candles float in oil, should I remove it somehow before the whole procedure and clean this place so that the old oil does not drip inside the engine? I will add that I recently changed the oil and the one from around the lights is black and looks old.
    2. Is the valve cover removed in any particular way? I mean the order of loosening bolts and tp.
    3. Is it worth to strengthen it and brush it with some special silicone when replacing the seal? I read a little about it and a lot of people do it. If so, please give me a hint what silicone it is.
    4. Can oil-flooded candles cause a drop in engine power? (this question is less important but it is good to know the subject thoroughly)
    Maybe there would be a good soul that would describe it briefly so that I would know how to go about it.
    On the internet I did not see any "active" photo guide and hence my questions, so by the way I thought it might be worth doing such a photo guide for this engine so maybe I will do it (of course in better quality photos, for those indistinct sorry).
    That's it. I cordially greet everyone asking for help :)
    I wish you a successful picnic ;)
    JaKotlinka
    Help: 7
    Rate: 119
    Remove oil, wash and dry cables. I recommend a new gasket. Tighten the valve cover alternately by screwing gently. Check engine operation and assess whether it works properly. Good luck
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6428
    If you do not remove this oil before removing the spark plug, you can break the engine.
    KOmpresor 10bar and fire then gas and clean and dry.
    Gasket for degreased metal + gasket in erling paste.
    Added after 31 [seconds]:
    Anyway, you don't have to bully candles as you don't need.
    Added after 41 [seconds]:
    Jackall
    Help: 77
    Rate: 396
    We give Reinz silicone only on bridge connections if they are. You can prophylactically grease both the sealing of the candles themselves. Degrease the contact surfaces. Buy a spray brake cleaner.
    JaKotlinka
    Help: 7
    Rate: 119
    KOmpresor 10bar and fire - don't do it because the whole engine and you will be in oil. Pump out a cleaning towel or paper towel. Air dry it rather at the end
    Help: 1405
    Rate: 6428
    Open it with a thin cloth that absorbs oil.
  • #7 16449264
    fux10
    Rate: 9
    Okay, thank you very much for your help, cleaning should probably not damage anything, someone has a photo, how should such a candle look right?
    Added after 2 [hours] 53 [minutes]:
    One more thing, can any power drops from such a flooded candle be?
    Jackall
    Help: 77
    Rate: 396
    Ignitions would fall in, but then it would light up the check.
  • #9 16450688
    fux10
    Rate: 9
    Okay, candles cleaned, but that's all I could do today, there wasn't much time. Tomorrow I probably won't take it, we finally have the holiday. I have already bought silicone recommended for sealing engines and after tomorrow I'm getting to work. In fact, probably all doubts have already been dispelled and the subject in my opinion is exhausted. Thank you very much for all your help and I wish you nothing broke :) Regards
The discussion revolves around a user experiencing oil leakage around the spark plug area in their vehicle, indicating a potential gasket failure. The user plans to replace the gasket themselves, having already purchased an Elring seal. Forum members advise on the importance of cleaning the area to prevent oil from entering the engine when removing the spark plug. Recommendations include using a compressor for cleaning, applying silicone sealant, and ensuring all surfaces are degreased before reassembly. The user expresses gratitude for the advice and plans to proceed with the repair after the holiday.
