[Solved] ZAFIRA I 1.8 16V - Persistent Oil Pump Seal Leak on Camshaft Side After Multiple Sealant Attempts
mmstan 7317 9
Why does the oil pump seal on the camshaft side keep leaking after several sealant replacements, and what should be checked or replaced?
The most likely cause is a worn groove or damaged running surface on the shaft where the seal lip works, or an incorrectly selected/oriented seal, not the oil pump itself [#16596843][#16669891] Check the shaft carefully at the seal contact area; a part that only “looks fine” can still have a narrowed or worn diameter that prevents sealing [#16596730][#16669891] Make sure the seal is the correct type and fitted the right way, because left- and right-handed seals exist and a wrong one can pump oil outward instead of inward [#16669891] If the seal spring is too weak, one suggestion was to shorten the spring, but only after verifying the shaft condition [#16669835] If the shaft is worn, the practical fix is to use a new unworn sealing surface or repair the journal; otherwise no sealant will hold for long [#16596843][#16669891]
  • #1 16596671
    mmstan
    Rate: 50
    I have a problem with the oil pump seal. When replacing the timing, the mechanic noticed sweating oil pump seal in the zafira 1.8 16V. The car is less than 200,000, I have it from new. Unfortunately we have already tried 3 different sealants and still have a leak. The leak is on the camshaft side. I am asking for advice on what the problem is. Should the pump need to be replaced, is it over-pressurized, or has the camshaft been damaged? The sealants were from three different companies.
  • #2 16596730
    Heinzek
    Help: 554
    Rate: 494
    What is the condition of the crankshaft where the seal is installed?
  • #3 16596791
    mmstan
    Rate: 50
    I mean? to be honest, I don't know anything about it, we have no idea for this leak ... the shaft looks fine
  • #4 16596843
    mechmajster
    Rate: 34
    It is possible that the groove on the journal is worn and none of them will seal any more.
  • #5 16596870
    mmstan
    Rate: 50
    Would you be able to show any sample photo explaining this defect? can something like this happen with this mileage? The car is 17 years old and its mileage is low.
  • #6 16669562
    mmstan
    Rate: 50
    I am back to the topic. We've already tried 4 different sealants and nothing continues.
    Can the oil pump give out too high pressure? When the car is idling after replacement, even an hour is not seeping. Only after driving for a long time does a strong leak appear. The roller looks ok.
    I read that it is possible to install a smaller sealant in some cars, does anyone know if it is possible for this model?
  • #7 16669835
    jerry1960
    Level 37  
    Help: 285
    Rate: 1561
    You can shorten the spring on the seal, but first check the condition of the shaft in the place where the seal works.
    g107r
    Help: 811
    Rate: 995
    And the sealant is correct? They are left-handed and right-handed, a common mistake when bought to size, not part numbers.
    One will scrape the oil into the engine, the other will scrub it outside. To the pump, there should be no problem with that, usually they should turn clockwise, but :?:
    At the bottom http://kestor.pl/web.n4?go=46 you have "ejectors".
    If it only looks, you can not finish it in the old place, but leave it to slide on the new, 100% unwashed one.
    Are you sure you are simmering? Not a gasket under the pump?
    Someone is fighting here too Link
    Shaft does not move sometimes? Still someone about the bushings in 2.0, and it's probably a twin.
    http://patrykstal.pl/regeneracja-biezni-uszczelni/ A small example, visible damage, you can have smaller, shinier, but with a narrowing, reduced diameter in the place where the sealant works.
    That that ? Perhaps this is an unfortunate detail.
  • #9 16669964
    kortyleski
    Help: 957
    Rate: 3860
    Soon. Either I don't understand something or I don't really see the connection between the oil pump and the camshaft. Where exactly is leaking
  • #10 17875793
    mmstan
    Rate: 50
    Second sealant purchased. That one had to be sloppyly put on, everything was fine after wearing it.
The discussion revolves around a persistent oil pump seal leak on the camshaft side of a Zafira I 1.8 16V, despite multiple attempts with different sealants. The user reports that the car, which has less than 200,000 km and is 17 years old, continues to leak oil after driving for extended periods. Responses suggest checking the condition of the crankshaft and the possibility of wear on the journal groove, which could prevent proper sealing. There are also considerations regarding the oil pump's pressure and the potential for using a smaller seal. The importance of using the correct sealant type is emphasized, as incorrect installation can lead to further issues.
