BMW n47 x3 177 Koni went out while driving and does not start
Slay222 8301 5
  • #1 16448799
    Slay222
    Rate: 20
    While driving the bmw x3 with the n47 engine, it went out and it does not start, but it does not burn
    after connecting the computer the error comes out 4CD0 and 4A3E
    Is there anyone who can help me with the fault
  • #2 16448951
    decybel91
    Help: 1024
    Rate: 4226
    The second error suggests low fuel pressure. If it goes out while driving, either the fuel pump in the tank or the filter or hoses etc.
  • #3 16448988
    Slay222
    Rate: 20
    New filters replaced 5 thousand ago
    How can I check the fuel pump both?
  • #4 16468678
    Slay222
    Rate: 20
    I replaced the fuel pump in the tank and it still bangs 4cd0 any advice, gentlemen, will anyone help?
  • #5 16475070
    decybel91
    Help: 1024
    Rate: 4226
    in THIS case keep exchanging until you hit something. Now it's time for injectors or a high pressure pump. (note sarcasm)
  • #6 17373321
    potter30
    Rate: 23
    Hello .
    Has the problem been solved?
    I have a similar case
