BMW E46 320D Not Starting: Fuel, Candles, Central Fix Attempts & Inpa Errors Explored
devb 13899 3
  • #1 17093475
    devb
    Until yesterday everything was ok
    Today, wanting to start the car only turns but does not start.
    Aku good half a year in frosts there were no problems with firing, the fuel is, on the board only a mistake from the pillow the rest ok. Candles warm after a while because they go out. Central works even tried the service key.
    I quickly started Inpa and got some errors, I coughed up but nothing helped.
    Any suggestions?
    BMW E46 320D Not Starting: Fuel, Candles, Central Fix Attempts & Inpa Errors Explored BMW E46 320D Not Starting: Fuel, Candles, Central Fix Attempts & Inpa Errors Explored BMW E46 320D Not Starting: Fuel, Candles, Central Fix Attempts & Inpa Errors Explored [/ Img]
  • #2 17094437
    migmig85
    Help: 85
    Rate: 337
    Have you tried the second key ??
    Check the fuel system, take 17 flat and release the fuel supply line on the injection and start spinning the engine as it will squirt fuel, we will already know something if it is dry, start by replacing the fuel filter only buy brand such as MANN KNECHT only the top shelf.
  • #3 17650494
    Edek1948
    Rate: 14
    I have a similar problem with my e46, do you have any solution?
  • #4 18315478
    migmig85
    Help: 85
    Rate: 337
    And what have you already checked?
