Connecting Brother MFC-J220 Printer to Two PCs: Gembird DSU-21 Switch vs I-BOX IUH3FB USB Hub
mmstan 6147 2
  • #1 16453239
    mmstan
    Rate: 50
    I would like to connect my brother MFC-J220 printer to two computers in one room.
    Do I have to use a printer switch for this purpose, e.g. Gembird Usb 2/1 Printer Switch (DSU-21)
    Can I also have a USB hub, e.g. HUB USB I-BOX 3.0 Black 4-Ports (IUH3FB)
    Are the ports being separated important? Do I have to use a USB AB cable for separation or can I also use a USB AA cable?
    Can you recommend a particular hub or are they all ok?
  • #2 16453329
    marianm68
    Help: 19
    Rate: 85
    Or maybe a good solution would be to use a print server?
    "The print server, as a device, can operate:
    o wireless - sharing of access takes place via a wireless network (Wi-Fi). It does not require a wired network connection to start sharing the printer.
    o wired - the device must be connected to a LAN. "
    You will have access to the printer from any computer on the network (I assume the network already exists).
    Read e.g. here: https://www.morele.net/ consciousosc/serwer-druku-jak-wybrac-print-server-jaki-najlepszy/1311/
    And check if your servers work with your printer.
  • #3 16454278
    mmstan
    Rate: 50
    I have a router in another room and I would have to drill holes and pull the cables to the router. That's how I pull the cord in the room.
