Connectivity Issue with HP CMI1312nfi MFP Printer and UPC Connect Box
6477 8
  • #1 16343992
  • #2 16344016
    sosarek
    Help: 9320
    Rate: 15532
    Have you set the printer's IP address from the UPC router's DHCP pool?
    Z
    Pka, Poznań, 60-850
  • #3 16344047
  • #4 16344051
    sosarek
    Help: 9320
    Rate: 15532
    Ok, have you tried to detect and install a network printer on your computer again?
    Z
    Pka, Poznań, 60-850
  • #5 16344072
  • #6 16344619
    sosarek
    Help: 9320
    Rate: 15532
    Log in to the UPC router and check the list of clients - if you can see the printer there.
    Z
    Pka, Poznań, 60-850
    sanfran
    Help: 963
    Rate: 3004
    If there is no LINK light on the port, it means that there is no connection on the lower layers.
    The problem may be with port speed negotiation.
    Enter the router settings and see if it is possible to force the port, e.g. in 100 or 10Mbps, and then connect the printer.
  • #8 16344997
  • #9 16345163
    KOCUREK1970
    Help: 3860
    Rate: 5488
    wenatychy wrote:
    No. The box itself assigns addresses, automatically.
    Then change it to its permanent IP address - you will install the printer drivers, restart the network and you will not print anything anymore, because the driver will have a different IP address before the restart than after it.
The user is experiencing connectivity issues with an HP CMI1312nfi MFP printer when attempting to connect it to a UPC Connect Box. Despite changing cables and using a netis E1 signal amplifier, the printer remains undetected, while it functions correctly with an old router. Suggestions include checking the printer's IP address settings, verifying the printer's presence in the UPC router's client list, and adjusting the router's port speed settings. The user successfully resolved the issue by changing the "Link speed" parameter to "100TX full" in the printer settings.
