Encountering iPhone 5s Error 4013 in iTunes - Possible Motherboard Issue?
Balzat 4113 10
How can I fix an iPhone 5s that enters DFU mode but fails to restore in iTunes with error 4013, when the computer and USB cable are known to work?
iTunes error 4013 on an iPhone 5s is usually a motherboard-level fault, so check PCB damage, the magnetic field sensor system, baseband EEPROM, Tristar, and possible NAND or CPU–NAND connection damage [#16454229] The missing parts next to the battery socket matter here: FL11 should be bridged, while the nearby capacitors can be ignored [#16454322][#16454783] After NAND removal and retesting, the board showing 508 mA and then a discovered short on the PP1V1_GPU line pointed toward a CPU/RAM-side problem rather than a simple software issue [#16458273][#16462332]
  • iPhone 5s restore fails with persistent Error 4013
    #1 16454177
    Balzat
    Rate: 14
    iPhone 5s
    After starting the phone, a picture is displayed informing about the need to connect the phone to iTunes.
    ITunes throws error 4013 when trying to restore the phone
    The phone can be switched to DFU mode and is detected by the computer and iTunes
    This is not a problem with the computer or the USB cable, because the same iPhone was successfully restored on the same computer with the same cable.
    I changed the motherboard of the damaged iPhone to the working one but still when I try to restore I get the same error, so the problem must be in the motherboard.
    Any tips?
  • #2 16454229
    RafalB
    Help: 91
    Rate: 222
    Balzat wrote:
    Any tips?
    Verify the magnetic field sensor system (compass), PCB damage, Baseband eeprom and Tristar system. It is possible to logically or physically damage the NAND memory or the CPU-NAND connection.
    iFixThis
    Łowmiańskiego 18, Poznań, 60-685 | Tel.: 516XXXXXX (Show) | Company Website: https://www.instagram.com/ifixthis.pl/
  • #3 16454322
    Balzat
    Rate: 14
    I examined the CD carefully and noticed that there were missing parts right next to the battery socket, four of them were still there next to it.
    FL11
    C279
    C23
    C25
    C275
    C22
    C9
  • #5 16457765
    Balzat
    Rate: 14
    I'm a fan of ...
    Pulling the screen off, I moved the U15 and the capacitors next to it.
    The capacitors were put in place, I took off the U15 and now the phone does not show any signs of life ... neither under the USB nor under the charger.
    I don't know if it makes sense to continue fighting with this album ...
    Why not buy an iCloud disc and reschedule the layouts?
    Will the plate get up without U15?
  • #6 16457942
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    I do not think so. This is a touch control chip.
  • #7 16458034
    gsmowiec
    User under supervision
    Help: 27
    Rate: 128
    I don't think you know what you are writing about ...
    Balzat wrote:
    I'm a fan of ...
    You are using too high a temperature and you probably overheated something while downloading U15.
    You would have to connect the phone to the power supply and check the power consumption off and after pressing power.
  • #8 16458106
    RafalB
    Help: 91
    Rate: 222
    First, you would have to know what the current condition of the album is and what else you can do with it.
    The icloud boards on the element dose are perfect besides the CPU, you can get everything you can :)
    iFixThis
  • #9 16458228
    Balzat
    Rate: 14
    In the meantime, I took off the NAND and refilled the FL11 C279 C23 C25
    The question of how to remove this black glue? Removing the NAND, a bit of the mask from my memory was torn off, but it's not a problem, I will paint it with the mask again.
    I set the voltage to 4.2V, only connected plus and minus, I don't know if you need to cheat the board somehow on this third pin.
    after applying voltage, consumption 0mA
    after pressing power 508mA consumption unchanged
    and now a surprise
    when I connect the USB and give power, the computer shows the message not recognized device without pressing power, consumption 214 mA
    after pressing power there is no change in consumption.
    Previously, there was no reaction after plugging in the USB ... strange
    On the connected USB, as I hold home and power after 10 seconds, you can hear the disconnection of the device, I let go of the power and the device is reconnected, but still not recognized.
    When I connect the phone with the battery, the charger draws 0.24A - the battery was almost full.
    So something else works out there
  • #10 16458273
    RafalB
    Help: 91
    Rate: 222
    You have a stick, if you downloaded nand memory then probably CPU / RAM
    iFixThis
  • #11 16462332
    Balzat
    Rate: 14
    There is a short circuit on the PP1V1_GPU line
    Added after 16 [hours] 46 [minutes]:
    My guess is I should take my CPU off now to see what's next?
The discussion revolves around an iPhone 5s encountering error 4013 in iTunes during restoration attempts. The user has already replaced the motherboard but continues to face the same issue, suggesting a potential underlying problem with the motherboard itself. Responses highlight the need to check various components, including the magnetic field sensor, PCB damage, NAND memory, and connections. Specific components like FL11, C279, and U15 are mentioned, with suggestions to bridge or replace them. The user also reports issues with power consumption and device recognition when connected to USB, indicating possible short circuits or further damage to the CPU or RAM.
