iPhone 5S iTunes Playback Error -1: Baseband Reballing Tutorial & Shopping List Needed
swiatek94 3354 7
  • #1 16700685
    swiatek94
    I warmly welcome,
    When playing iOS on iPhone 5S, I get error -1 at the end of the process. I have already read a few threads and I will probably have baseband reballing, but the problem is that I have never performed such a procedure. I have two damaged records from 5S and 6 at home, so I could learn reball on them first before I do it in the 5s.
    I have rummaged in iPhones more than once, basically I took apart every model and exchanged something in it, but I never took the motherboard and rummaged in it, but I would like to finally learn and start the adventure with repairing U2, baseband, nand e.t.c.
    Could someone write me an exact shopping list for this procedure? I will be extremely grateful, unless such an answer is already in some thread, I am sorry and I will continue to search the forum.
    greetings :)
  • #3 16701428
    hacker_ice
    Help: 36
    Rate: 101
    As for the problem of error -1, unfortunately, but the baseband is dying or has already died and when you heat it up it's over, these systems cannot be programmed and cannot be exchanged with any other similar situation with a lack of signals in the iPhone 6. Due to age these phones are already happening so that more and more of them appear with such baseband problems and no one fixes it, maybe only China is doing it by transferring CPU, baseband, eeprom and nand to a good disc here it is as no fix.
    Apple Surgery
    Śląska, Bargły, 42-262 | Company Website: https://applesurgery.com.pl
  • #4 16701778
    gsmowiec
    User under supervision
    Help: 27
    Rate: 128
    Exactly! In addition, the baseband is still glued on Fridays, so even raising it, cleaning the pads and re-soldering is already mission impossible. In sixes it sometimes helps to restore two connections under baseband.
  • #5 16702340
    RafalB
    Help: 91
    Rate: 222
    I would also verify Baseband eeprom soldering, it's best to do reball. The content of the baseband eeprom often flies. Sometimes Baseband power supply. However, the most popular topic is degradation of the Baseband binder as explained above.
    iFixThis
    Łowmiańskiego 18, Poznań, 60-685 | Tel.: 516XXXXXX (Show) | Company Website: https://www.instagram.com/ifixthis.pl/
  • #6 16702611
    swiatek94
    So I understand that it is not possible to take a baseband from another disk and insert it into the repaired disk, the baseband is not programmed, but rather nand?
    Anyway, I will finish reading the soldering thread this weekend, which gave nutergsm, I will buy the necessary parts and try.
    I have nothing to lose, and I intend to act in this direction in the near future.
    There are already 2 PS3 with YLOD waiting in line, so maybe at least the consoles will be able to get back on their feet: d
  • #7 16702883
    RafalB
    Help: 91
    Rate: 222
    swiatek94 wrote:
    baseband rather not programming, but nand?
    Eeprom is programmed, not nand. Nand after SN is nothing to Baseband, but SN from Nand must match SN in eepromie, that everything worked ;) There is also a corrective eeprom but its content is not important (you can reschedule the system from another board)
    iFixThis
  • U2_RF fault can mimic baseband error -1
    #8 16703381
    kosiasty
    Rate: 20
    -1 is not always a baseband, in many cases the problem was caused by the U2_RF system, e.g. on the PP_LD09_PLL_1V05 line when it comes to 5s.
    However, to the author of the post, I suggest that you give someone with experience to do the repair, since you have never done it.
    This is not an easy task, especially in 5s flooded with resin, you tear the pads and the plate will be suitable for a dose. You should start on low-value discs if you want to learn this ...
    But if you're about to go about it, it's best to start with a gentle reflow on BB to verify. If it works and you catch the net, you found the culprits. Just remember that the same warming up will not be enough, the problem will return again, a matter of a few hours, or even a few days. It is necessary to perform reballing if the repair effect is to be long-lasting.
The discussion revolves around the iPhone 5S experiencing an iTunes playback error -1, which is often linked to baseband issues. Users suggest that the baseband may be dying or already dead, making it difficult to repair. Baseband reballing is recommended as a potential solution, although it is noted that this process is complex and requires experience. Participants emphasize the importance of verifying the baseband EEPROM soldering and suggest starting with reflowing the baseband to diagnose the issue. The conversation also touches on the compatibility of baseband components and the necessity of matching serial numbers between NAND and EEPROM for successful repairs. Caution is advised for beginners, with recommendations to practice on less valuable devices before attempting repairs on the iPhone 5S.
