[Solved] Connecting Vodafone Router to German Telephone Socket: Cable Setup & Activation Issues
norris99 14856 5
  • Should the two loose socket wires be connected?
    #1 16454382
    norris99
    Rate: 25
    Hello. I am in the process of establishing a permanent internet connection in Germany and I have a problem because I cannot connect to the router according to the vodafone operator, everything is activated and the signal has been turned on. I decided to unscrew the socket and I see that two cables are connected and two are not my question is whether it should be connected or otherwise. Thank you in advance and I'm sorry how I set up the topic in the wrong department.
    Connecting Vodafone Router to German Telephone Socket: Cable Setup & Activation Issues Connecting Vodafone Router to German Telephone Socket: Cable Setup & Activation Issues Connecting Vodafone Router to German Telephone Socket: Cable Setup & Activation Issues Connecting Vodafone Router to German Telephone Socket: Cable Setup & Activation Issues
  • #2 16454404
    sosarek
    Help: 9320
    Rate: 15541
    Is the phone connected to this socket working properly?
    What service is this? What equipment? Filter installed?
    Z
    Pka, Poznań, 60-850
  • #3 16454429
    norris99
    Rate: 25
    I don't know if the phone works because I don't have one and I don't know if it was before. The vodafone dsl service 16. There was no filter in the set with the router and there is no filter in the connection description.
  • #4 16455005
  • #5 16455080
    marqqv
    Level 32  
    Help: 162
    Rate: 610
    This plug in the photo from the router? Give a picture of the back of this router. What do you have there .
  • #6 17382895
    norris99
    Rate: 25
    You came from the telecom and connected.
    Greetings.
