Challenges with Installing INVENTOR 2014-2018 from Student Autodesk on New Computer
Zolty_Ananas 8286 5
  • #1 16454881
    Zolty_Ananas
    I warmly welcome,
    I need to install Inventor from the student autodesk website. I had once installed on another computer and it worked. I have currently changed my computer and installed AutoCad Eletrical from the same site and it works. Now I need Inventor and cannot install any of the 2014-2018 versions. During installation the message like on the picture is displayed. I have also inserted an installation log, maybe there is someone here to help solve the problem. Thank you in advance.
    • 2.txt (58.28 KB) You must be logged in to download this attachment.
  • #2 16455838
    Artur k.
    Help: 1279
    Rate: 1700
    Here's the answer:
    Another Autodesk installation / update is currently running on this computer. Wait for it to finish and then click Retry. 2017/4/30: 10: 40: 44 matru LAPTOP-14TABG3E Path_Length: 179
  • #3 16459099
    Zolty_Ananas
    I have had a problem for a good 2 weeks, I can't see any updates, I turned off everything possible from the task manager and then the same; /
  • #4 16459170
    enhanced
    Help: 963
    Rate: 881
    The logo says that it can't download something
    2017/5/4:20:34:35	matru	LAPTOP-14TABG3E	Download	Aborted	CM	https://edutrial.autodesk.com/NET18SWDLD/2018/INVNTOR/6C2FF9C7-B8A4-4CA4-BA59-ECD5F68B4106/WI/{C2EAC499-E890-49EF-8F03-3D000AA9A4FD}/CM.tar.lzma2
    2017/5/4:20:34:35	matru	LAPTOP-14TABG3E	Install	Autodesk ® Material Library 2018	Failed	Download Failed, Installation aborted, Result=1603
    2017/5/4:20:34:35	matru	LAPTOP-14TABG3E	Rollback	Microsoft Visual C++ 2013 Redistributable (x64)	Failed	Installation aborted, Result=1619
    2017/5/4:20:34:36	matru	LAPTOP-14TABG3E	Rollback	Microsoft Visual C++ 2013 Redistributable (x86)	Failed	Installation aborted, Result=1619
  • #5 16459245
    Zolty_Ananas
    Damn, I have no idea what; /
    And I was reminded that when I start the computer again, I get this message (as in the picture) but since installing the electrical from 2 months ago, I do not know if it has any effect. But electrical works all the time.
  • #6 16462611
    BUDiKOM_wsparcie
    Regarding the errors that appear to you at startup: this error applies to the application that checks for updates to Autodesk software. If you do not want this error to appear or remove it from the autostart or download the latest version from the Autodesk website (the latest version should start correctly) or in the location
    C: \ Program Files (x86) \ Autodesk \ Autodesk Desktop App find AutodeskDesktopApp.exe and assign it administrator privileges.
    Regarding the installation itself, I suggest you first download media to disk using the "download via browser" option (do not use the Autodesk installer)
