stilo 1.616v - where there is a feature with a crankshaft for timing
jorgg 9669 5
  • #1 16392355
    jorgg
    Where in the 1.6 16V stilo there is a feature on the crankshaft to set the timing
  • #2 16392401
    jenusz11
    Help: 33
    Rate: 195
    there should be a mark on the pulley and timing case
  • #3 16392519
    jorgg
    It's not there
    Added after 8 [minutes]:
    There are strange features
    Please help diagram
  • #4 16392523
    drdrug
    Help: 25
    Rate: 178
    Write which year this Fiat is in power.
    If 76kw for proper setting, blocking and timing voltage you need locks.
    https://obrazki.elektroda.pl/5182271400_1293533488.jpg
    If the Opel 77 kw engine is shaft per hour. 6, marks on the rollers to the inside, i.e. to each other.
  • #5 16392784
    toku74
    Help: 123
    Rate: 727
    As you remember, every 1.6 16V you set the shaft to "0" with a dial indicator. The timing phases will split on these marks on the wheel.
  • #6 16393985
    drdrug
    Help: 25
    Rate: 178
    You don't set every sixteenth to the clock :-) If the stilo is oplowski 1.6 16v z16x then you set the timing to the factory marks placed on the housing or gear wheels. And 1.6 1.6 Fiat should be done on locks and like a clock because for the correct tension of the belt you need a device for tensioning the tension roller and the need to loosen the gears of rollers. Of course you can do it with a handyman, but it is a lottery, it will either fail or it will lame and work unevenly or it will walk well :-) In my humble opinion, if the manufacturer has seen the locks / tools for the correct operation of any timing mechanism, this is not for my own view :-)
    Btw you can close because the topic will not develop anyway.
