[Solved] Simultaneous isolation of two bluetooth headphones for one TV
sebry 43221 12
How can I use two Bluetooth headphones at the same time with one Panasonic TV?
The TV’s built-in Bluetooth can connect to only one headset at a time, so to use two headphones you need an external solution [#16469180] The simplest workaround is to connect one pair directly to the TV’s headphone output and use a separate Bluetooth transmitter for the other pair, or use a transmitter on the TV’s optical output and pair each headset through its own transmitter [#16469180][#16469347] A dual-headphone Bluetooth transmitter also exists, but one user reported that it costs about 180 and has a mini-jack input, so it is not exactly cheap [#16490604] Reports on cheap “1-to-2” transmitters were mixed, with concerns about reliability and audio/video sync, so the safer recommendation is a reputable transmitter rather than a very cheap one [#16469347][#16473335]
  • #1 16468572
    sebry
    Rate: 11
    I have a Panasonic TV: TX-47AS650 and two pairs of bluetooth headphones: Sony DR-BTN200M, Sony SBH60.
    I would like to use both headphones while watching TV.
    In practice, it looks like the TV sees both headphones but you can pair with only one (I can choose).
    Does anyone know and can recommend a cheap, tested, convenient and aesthetically pleasing solution to this problem?
    Greetings,
  • #2 16469180
    Polon_us
    Help: 1184
    Rate: 1280
    TV, in fact its connection BT can handle only one device at a time.
    This is due to the BT standard.
    In this case, I see two solutions:
    1 - SBH60 headphones can be directly connected to the TV. The TV has a headphone output.
    2 - obtain a BT transmitter and connect it to the TV, eg optical output. Each pair of headphones would have its own dedicated BT transmitter.
    Note: this additional transmitter must support the NFC ("Near Field Communication") function
    so that the connection to the pair of headphones works. Both pairs of headphones have this feature built-in.
    An example of such a transmitter -> link
  • #3 16469222
    sebry
    Rate: 11
    Hello, Polon_us
    Cable connection is not an option.
    The transmitter from the link you gave away due to the price.
    I found something like that (two-channel transmitter supporting two H-366T headphones):
    http://www.dx.com/p/h-366t-1-to-2-bluetooth-v4-0-audio-transmitter-black-383556#.WRQERTVAqso
    Will there be problems with this?
    And another question, is this configuration possible?
    one of the headphones separated from the TV and the other separated with the transmitter (single channel eg: http://allegro.pl/bluetooth-nadajnik-adapter-audio-bezprzewodowy-i6791281606.html) plugged in to the headphone TV?
    Will there be no problems with this configuration, will I have to disconnect the transmitter from the headphone jack in order to be able to listen to the TV without headphones?
    And finally: why this additional transmitter must necessarily support NFC?
    Polon_us
    Help: 1184
    Rate: 1280
    Well, I can not express myself about this invention. I have looked for some opinions about this device. They are divided 50% / 50%.
    In general, evaporation is cumbersome, although feasible.
    In one or two cases, people complained about the asynchronization between sound and video on TV.
    A colleague will try, it's free.
    one of the headphones separated from the TV and the second one was paired with the transmitter
    I am writing about this in my post - option # 2. An example of a transmitter I took the first from the list Google showed me without paying attention to the price, I wanted to show the idea of connection.
    One transmitter would be a TV and the second one would be a transmitter. I have not expressed this idea very precisely.
    sebry wrote:
    Will there be problems with this configuration,
    If the colleague is referring to this transmitter from Allegro, please answer the question first
    "How do I put headphones with this transmitter?"
    Podpowiem - it has to do with the question "Jak mnie ..."
    Headphones owned by a colleague have this feature built in, also just look through their instructions. And everything will be clear.
  • #5 16470273
    sebry
    Rate: 11
    Hello, Polon_us
    From what I have read, NFC is not necessary to establish a connection between bluetooth devices, and it does not make sense at devices (transceivers) a few meters away (I am so steeply listening to my TV).
    So what do you think about when buying a sender / transmitter / bluetooth transmitter so that it can pair with headphones without using NFC?
    Polon_us
    Help: 1184
    Rate: 1280
    Let a colleague contact a seller of these BT transmitters / receivers.
    Please ask how it looks practically the pairing procedure of the headphones with the transmitter sold by a given delinquent.
  • #7 16472827
    sebry
    Rate: 11
    If there were no doubts as to the method and effectiveness of the pairing and the quality of the combination of devices sold on the market, this thread would not exist. The most interesting is that on Youtube etc. everything looks so banal - but I have doubts (resulting from ignorance) hence this thread.
    Warning about unreliable Bluetooth transmitters and Wi-Fi interference
    #8 16473335
    KOCUREK1970
    Help: 3862
    Rate: 5490
    Polon_us wrote:
    Please ask how the pairing procedure of the headphones with the transmitter sold by a given delinquent looks like.
    You will not get the answer ...
    It is to sell (it does not necessarily work - taking into account the price, a lot of people are simply to send to the rubbish of cities and send back and demand a refund).
    @sebry
    Please also remember that while the built-in BT TV has "credibility" of action, I would not place great hopes in an additional "invention".
    BT is nothing but wifi waves - if a colleague uses a wifi network there may be problems (BT operates in the 2.4 GHz band).
  • WiFi and Bluetooth pairs worked simultaneously without dropouts
    #9 16474441
    sebry
    Rate: 11
    Hello, Kocurek1970
    I agree with you about the practices of some producers (especially those from China) - it does not necessarily work but it is important that it is sold.
    I am surprised by the price of BT transmitters, because with a reputable company, you have to spend over PLN 200 (for a nówka).
    As for the BT-WiFi collision problems, today I tested the operation of WiFi pairs near the WiFi router:
    TV (BT) - headphones1 (BT), smartphone (BT) - headphones2 (BT) - everything worked beautifully (simultaneously) without delay and disconnection.
    At the end: I will be looking for a transmitter among renowned stimulants, because I do not want to check the Chinese anymore.
    Mihau19
    There is a ready transmitter for two pairs of words, only the price 180 with charged runs a few hours neat and has a mini jack input. Treatively to tv, kom.radia and tp.
    Polon_us
    Help: 1184
    Rate: 1280
    @ Mihau19 - interesting ...
    Maybe more details - model / producer and website address where you can find this miracle.
    This is a technical forum - the "highlight" does not mean much here ...
    tadeosto
    Rate: 19
    I have two BT receivers in two rooms. Can the laptop "transmit" simultaneously to both?
  • #13 17432460
    sebry
    Rate: 11
    I left the topic - I only use one receiver - transmitters are too expensive.
The discussion revolves around the challenge of connecting two Bluetooth headphones (Sony DR-BTN200M and Sony SBH60) to a Panasonic TV (TX-47AS650) simultaneously. Users note that the TV can only pair with one Bluetooth device at a time due to Bluetooth standards. Suggested solutions include using a Bluetooth transmitter connected to the TV's optical output, allowing each headphone to connect to its own transmitter. Concerns about the cost and effectiveness of various transmitters are raised, with some users expressing skepticism about cheaper models and potential issues with audio synchronization. The necessity of NFC support for transmitters is debated, with some users arguing it is not essential for pairing at a distance. Ultimately, users recommend seeking reputable brands for transmitters to avoid issues commonly associated with lower-quality products.
