32-inch MANTA LED 9320E1S Android TV vs Thomson 32HB5426 Smart TV 3.0: WiFi & Sideways Viewing
mateusz62gim 5292 3
  • #1 16468648
    mateusz62gim
    Good morning, I'm thinking about buying a new TV and I don't know which one to choose. Which 32-inch TV with smart TV and WIFI is better to choose MANTA LED 9320E1S with Android TV or Thomson 32HB5426 with Thomson Smart TV 3.0? Someone may have been dealing with one of these televisions?
    1. How big is the room where the TV should be?
    - this room will fit a TV with a diameter of up to 32 inches
    2. How far are we from the TV screen?
    - 2.5 m
    3. How many people sit in front of the TV?
    - 2-3 people
    4. Are we sitting in front of the screen or sideways to the screen?
    - sideways
    5. Is the TV supposed to stand or hang?
    - is to hang
    6. What TV do you currently have?
    - there was previously a monitor with a TV function
    7. What do we want the TV to have?
    - smart TV (the ability to use an internet browser, YouTube, the ability to install additional applications)
    - WiFi
    8. What devices?
    - MANTA LED 9320E1S
    - Thomson 32HB5426
    9. Are you going to surf the internet?
    - Yes
    10. Do you intend to play games - if so, how much% per day?
    - probably not
    11. Brand preferences?
    - no
    12. Size preferences?
    - The maximum screen size is 32 inches
    13. Do you watch more in the evenings or during the day?
    - in the evenings
    14. What is the maximum amount you plan to buy?
    - 1000 PLN
    15. How often do you change TV sets at home?
    - rarely
    16. Do you use internet applications often?
    - Yes
  • #2 16469164
    Ludwik XVI
    Help: 1325
    Rate: 788
    Niche models. So-called marketers. It's hard to compare, because nobody tests such models.
    Since you use intensively smart, take it with Android but check how it works on this tv, because it may not be smooth enough ...
  • #3 16472283
  • #4 16610933
    mateusz62gim
    Problem solved
