With full gas addition and load, the car jerks, how would it get no fuel?
Ciqita_PL 7440 8
  • #1 16469653
    Ciqita_PL
    Hello, I am the owner of the Ford Focus MK2 FL 1.8TDCI and I have a problem with jerking the engine. If I drive alone without a load and normally the car walks correctly, but if I just press the accelerator to the end it begins to choke, choke, and the worst is when I have passengers on board and I try to overtake another car tug enough that I can't overtake it and I'm riding frogs. Can anyone advise me something, mention that filters replaced.
  • #2 16469788
    Piotr2608
    Help: 851
    Rate: 4483
    Have you changed those fuel or air filters long ago?
    At idle, does the engine enter the engine correctly?
    ZimTech Piotr Zimny
  • #3 16469801
    Ciqita_PL
    The fuel filter was replaced half a year ago, and the oil one month ago.
    The engine works well all the time, but as I mentioned above when adding gas to the max it begins to choke.
  • #5 16469825
    Ciqita_PL
    A week ago
  • #6 16469855
    marek49ae
    Help: 57
    Rate: 253
    The fuel filter can be disposed of after one refueling.
  • #7 16469858
    Piotr2608
    Help: 851
    Rate: 4483
    The power demand increases with the engine load. Let your colleagues speak but it is worth checking the tightness of the vacuum and air hoses. It is worth checking the correct operation of the EGR.
    ZimTech Piotr Zimny
  • #8 16469861
    marek49ae
    Help: 57
    Rate: 253
    There is still a dragon to check in the tank, because there may also be miracles.
  • #9 16469866
    Ciqita_PL
    I'll try what's left for me, it's not an expensive party, thank you for your interest. If anyone else would have any idea, please join the topic and I will answer after changing the filter
✨ The owner of a Ford Focus MK2 FL 1.8TDCI reports engine jerking when accelerating under load, particularly with passengers. The vehicle operates normally when driven alone. The owner has replaced the fuel filter six months ago and the oil filter one month ago, with the air filter replaced a week ago. Suggestions from the forum include checking the air filter, ensuring the tightness of vacuum and air hoses, and verifying the operation of the EGR valve. There is also a mention of potential issues within the fuel tank.
