Ford Focus Mk2 (2007) - 32-Pin Cube Meter Connection for Short Tests: Seeking Pin List
lukaszooo 12507 12
How can I identify the 32-pin connector pins on a Ford Focus Mk2 (2007) instrument cluster so I can power it and do short bench tests?
To bench-test the Focus Mk2 cluster, connect power, ground, ignition, and the CAN lines: pin 6 = ground, pin 4 = ignition switch, pin 32 = постоянный +12 V, pin 17 = CAN L HS, pin 18 = CAN H HS, pin 22 = CAN L MS, and pin 23 = CAN H MS [#16470160] The cluster is CAN-controlled, so you will not get far with only simple power pins [#16470063] If you are wiring it through an ELM/OBD connector, one reply maps the cluster to the interface as 6→5, 4→16, 32→16, 17→14, 18→6, 22→10, and 23→2 [#16470372] Another photo-based correction says the remaining two lines are 22→11 and 23→3 on the OBD side, and reminds that the pin numbering starts on the right in the photo [#16470640][#16471800]
  • #1 16469895
    lukaszooo
    Rate: 25
    Hello, I have a meter from Focus mk2 2007, the meter has one 32pin cube. I am looking for a meter pin list to run it for short tests.
  • #2 16470063
    janusz2008
    Help: 170
    Rate: 515
    Don't look, it's CAN.
  • #3 16470160
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    6 - mass
    4 - ignition switch
    32 - a constant plus
    17 - CAN L HS
    18 - CAN H HS
    22 - CAN L MS
    23 - CAN H MS
  • #4 16470291
    lukaszooo
    Rate: 25
    Buddy, thanks a lot, I'll be testing tomorrow :)
    I see that you have a lot of knowledge about meters, maybe you know how are the pins on the ELM interface from viakena v3 ???
  • #6 16470372
    lukaszooo
    Rate: 25
    He wants to connect with the ELM v3 cable from viaken to the counter on the table without connecting to the car.
    So I have to connect like this:
    Counter cube Cable ELMv3
    6 - ground pin 5
    4 - pin 16 ignition switch
    32 - constant plus pin 16
    17 - CAN L HS pin 14
    18 - CAN H HS pin 6
    22 - CAN L MS pin 10
    23 - CAN H MS pin 2
    grala1
    Help: 1495
    Rate: 5052
    22-11
    23-3
    The rest approx
    Camera weak but visible.
    On the left the counter, on the right the OBD connector.
  • #8 16471779
    lukaszooo
    Rate: 25
    The matter is not as simple as it seemed. In the obd2 plug in the car, 12v is on pin 16 and on the can pins 2.5v.
    The problem is that the elm cable from viakena does not have pin 16 ..... I tried to connect without 12v but it does not connect.
    Any ideas ? Ford Focus Mk2 (2007) - 32-Pin Cube Meter Connection for Short Tests: Seeking Pin List Ford Focus Mk2 (2007) - 32-Pin Cube Meter Connection for Short Tests: Seeking Pin List
    grala1
    Help: 1495
    Rate: 5052
    We go back to school to learn to count :)
    8, 9, 12, 13 are missing.
    The first pin is on the right in the photo and in the slot on the left.
    Think a little :)
  • #10 16471863
    lukaszooo
    Rate: 25
    Czech mistake, I had a cable in my hand and counted against the socket :)
  • #11 16479741
    ziomal156
    Did you change the soft with this viaken? Because I can not change at home, an error pops up once before, once later, even when I change the block sizes. I think you need to set something up in the USB driver, buffers, etc., I've seen it somewhere but I can't find it. Then I only have to set the IDSem counter. But soft 20x very old.
  • #12 16479974
    lukaszooo
    Rate: 25
    No buddy, I didn't play such things.
  • #13 18142784
    paco69
    Rate: 15
    Gentlemen, you can use the standard elm327 diagnostic interface to put the counter on its feet, i.e. check its backlight? By connecting to the appropriate pins in the CAN L and CAN H counter socket, power and ground?
The discussion revolves around the 32-pin cube meter connection for the Ford Focus Mk2 (2007) and the need for a pin list to conduct short tests. A user seeks assistance in identifying the pin connections for the meter, which is primarily based on the CAN protocol. Several users provide a detailed pin list, indicating connections for ground, ignition switch, constant power, and CAN lines. There are also inquiries about using an ELM v3 interface cable for testing the meter outside of the vehicle, with discussions on the challenges faced due to missing power connections in the ELM cable. The conversation highlights the importance of proper pin connections for successful diagnostics and testing of the meter.
