Adding a LAN Network Drive to Orange Sagemcom WiFi-11n Fast 2704 Router for Home Projects Storage
Gozon 4089 12
Can I use my Orange Sagemcom Fast 2704 router as a LAN network drive for storing small project files remotely from work, and what setup is best?
You can do it, but not as a simple LAN-only drive on that Sagemcom for remote access; the better solution is a NAS or a device/router that supports FTP/Samba, plus VPN and DDNS for access from outside the local network [#16472753][#16473025] The Sagemcom’s USB storage is only available locally, so it will not solve remote access by itself [#16473025] If you try to use a drive over the internet, transfer speed will be limited by the slower of the two internet links, so WAN performance can become very poor compared with a local USB drive [#16471962] One practical setup mentioned was a NAS connected to the router, port forwarding for FTP, and a constant domain from noip.org/noip.pl, or OpenVPN if you want a more secure remote connection [#16473025] An even simpler alternative is to keep a computer and USB drive permanently connected, but that costs continuous power [#16472753]
  • Seeking guidance on router-connected 2.5-inch network storage
    #1 16471914
    Gozon
    Hello all
    I would like to be able to save my home made projects right at my workplace. I am currently using a 2.5 drive and an ARDATA bay. Cool solution, but it starts boring me.
    At work I have an orange segemcom wifi-11n fast 2704 router. I am thinking about two options. The first is to save directly to the computer, but then it would have to remain asleep and be constantly connected to the network.
    The second option is a LAN network drive connected directly to the router. Then the power would be connected only to the disk and router .. It would be left to connect the disk with the computer.
    Minimum disk requirements. Ideally 2.5 inches of 100 GB capacity is enough for me.
    As you can see, my knowledge on this subject is based on assumptions, hence the request for help and guidance on the right track.
    Marcin
  • WAN bandwidth limits remote drive transfer speeds
    #2 16471962
    bogiebog
    Help: 2569
    Rate: 1530
    Currently the drive is connected with usb2 or usb3?
    What large files are you saving?
    What MegaByte / Sec transfer do you expect?
    What's the internet like at work? upload? download?
    What's the internet like at home? upload? download?
    When you work at home and drive at work it
    - disk write speed = MIN (dom_net_upload, praca_net_download)
    - speed of reading from disk = MIN (dom_net_download, praca_neta_upload)
    e.g. work 20/2 mbs, house 10/1 mbs.
    therefore disk write - 1mbs, (0.16MB / s :) , 2mbs disk read (0.32MB / s)
    USB2 disk is 20-30MB / s write / read, so please think carefully on remote / network disk over WAN / internet.
  • #3 16472361
    Gozon
    It does not need high parameters. Files with programs for a CNC milling machine rarely exceed 1 MB. Sometimes the documentation weighs a bit but it is max 20 MB and I will not send it.
    The drive can be connected to USB 3.0 because I have free ports of this type.
  • #4 16472753
    bogiebog
    Help: 2569
    Rate: 1530
    Comp at home, hard drive at work, I definitely recommend a VPN home-work connection, and a NAS network drive for this, or a computer + USB drive permanently connected.
  • NAS or bridged router enables external disk access
    #5 16473025
    Heinzek
    Help: 554
    Rate: 494
    If it's such a small size, why don't you send it by e-mail?
    The best and easiest way is as he wrote @bogiebog , i.e. the NAS server (e.g. the popular zyxel nsa310 - transfers max ~ 30MB / s) you connect to the router, redirect the port to ftp and set the constant domain to noip.org or something similar.
    Access to the disk from the internal network via samba and from the outside you have ftp.
    Cost ~ 250 PLN
    If you already have a USB drive, you can put this sagecom in the bridge, and then set up an ordinary router with a USB port (e.g. TP-Link WR843N - transfers max ~ 10MB / s) and turn on the ftp and samba server on it, Here you also have a gate and you can upload gargoyle to it and make yourself a simple VPN on OpenVPN, in gargoyle you can still set up a free and not requiring activation ddns noip.pl client.
    Cost ~ 100 PLN + devoting time to education and configuration.
    The current sagemcom has a USB but it is only available locally.
    You can still use the computer while it is on and connect to it via TeamViewer, here the cost is only the power of the computer on.
    there are many ways
  • #6 16473353
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Not a bad idea, actually.
    Alternatively, purchase the Premium account options (larger attachments, no account capacity limit, security, etc.).
  • #7 16473358
    bogiebog
    Help: 2569
    Rate: 1530
    Instead of email, xxx-drive, google-drive or one-drive.
  • #8 16473391
    KOCUREK1970
    Help: 3860
    Rate: 5488
    I trust Polish e-mail addresses more than disk spaces that do not even have one server in Poland.
    And since these are business matters, it is better not to get the Americans in the hands of it ...
  • #9 16473411
    bogiebog
    Help: 2569
    Rate: 1530
    Before uploading, encrypt it.
  • #10 16474181
    KOCUREK1970
    Help: 3860
    Rate: 5488
    When someone encrypts something, he has something to hide ... - after all, every NSA employee knows it :D .
  • #11 16474192
    Heinzek
    Help: 554
    Rate: 494
    Multiple ways to upload / move a file, fear of "Americans". Maybe instead of a hard drive carry a "small" flash drive attached to the keys?
    With these sizes, 32 GB is exaggerated, and the transfer compared to the neostrad connection (max 20 / 1Mbit / s) is much better.
  • Using a keychain flash drive or phone storage
    #12 16474235
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Or dump files directly on the phone (smartphone to its memory card) - most phones already have LTE, so in the event of a problem with connecting the phone itself, you will be able to quickly "roll" the file to the destination.
    Many ideas - but here the author himself has to ;) show us a choice, then you will also be able to think about possible problems and try to eliminate them (unfortunately each solution always has some "but" ...).
  • #13 16494202
    Cr4sheR
    Help: 8
    However, I recommend the cloud for this. Pros:
    - availability from all over the world
    - no complicated configuration
    - data security (not including surveillance)
    icloud, onedrive, googledrive etc (probably the easiest google drive)
The discussion revolves around the user's desire to store homemade project files efficiently using an Orange Sagemcom WiFi-11n Fast 2704 router. The user considers two options: saving files directly to a computer or using a LAN network drive connected to the router. Responses suggest using a NAS (Network Attached Storage) for better accessibility and data management, with recommendations for specific models like Zyxel NSA310 and TP-Link WR843N. Alternatives such as email, cloud storage (Google Drive, OneDrive), and USB drives are also proposed, emphasizing the importance of data security and ease of access. The user is advised to consider the speed of their internet connections when choosing a solution.
