  • A homemade x86 NAS server was built to move over 4TB of HDD data from a desktop to a laptop setup.
  • Xigmanas was chosen over FreeNAS because it can connect NTFS drives and share them over the network.
  • The build used an AsRock H81M-DG4 motherboard, 8GB RAM, an Intel Celeron G1840, and cost PLN 120.
  • SilentiumPC cooling replaced the stock cooler, making the system quiet enough that only the disks are heard, though the IBOX 400W PSU is still temporary.
  • One day I was faced with the fact that I had to change my desktop computer to a laptop. The laptop is chosen, but the dilemma of what to do with the data that is on the HDD drives and there is over 4TB of them.
    The idea of a fast NAS server, but their price knocked me off my feet.
    I started searching the internet and found two interesting ready-made x86-based NAS systems - Bingo!
    These systems were FreeNas and Xigmanas (formerly nass4free).
    However, xigmanas won by default in that you can connect NTFS drives and use them over the network. Unfortunately, FreeNas does not allow this, it is a system designed rather for much more powerful machines.
    The system is there, I have disks, I had to find a processor and a motherboard would fall out.
    After browsing through the OLX, I found the AsRock H81M-DG4 motherboard + 8gb RAM + Intel Celeron G1840 processor for PLN 120.
    It looked like this:
    We are building our own NAS server
    Okay, but this cooling is going to be a bit loud so after browsing Facebook I found a SilentiumPC cooling for half the market price. I didn't think twice and my motherboard looked like this:
    From there, only the disc is heard! :D
    The power supply for me is just anything, because it is only IBOX 400W, but for now it has to be enough, I will probably replace it with SilentiumPC.
    The whole thing looked like this:
    In the following, I will try to describe the relatively quick configuration of the Xigmanas system :)
    kassans
    Level 32  
    kassans wrote 1820 posts with rating 412, helped 130 times. Live in city Zduńska Wola. Been with us since 2011 year.
  • #2 18483519
    Łukasz_W
    HDD and data recovery specialist
    Help: 633
    Rate: 658
    Then replace this Seagate / these Seagates (?) With something else, because all this fun may end in the imminent loss of those four terabytes.
    HEX SERWIS
    Smołdzinska 2B/16, Kobysewo, 83-304 | Tel.: 530XXXXXX (Show) | Company Website: https://hex-serwis.pl
  • #3 18483541
    dvo
    Rate: 11
    I wonder what power consumption your set has. I would be more inclined to buy a second-hand nas or build something for thinclient. If the budget limits.
  • #4 18483593
    krzbor
    Help: 42
    Rate: 1072
    I approached the problem of my own NAS differently - it is supposed to be a good, reliable computer, of course, with 2 disks in mirroring, with a passively cooled processor (I chose the ATOM motherboard) and relatively low power consumption. It's the main computer for me - it works as a NAS, FTP server, website. It also handles all smart home communication. I chose openmediavault (OMV) for the software mainly because it is based on Linux, not FreeBSD. A better class power supply - it's just supposed to work for many years and so far it works :)
  • #5 18483615
    noyo
    Rate: 18
    I went in Intel Atom DN2800MT + 2x WD red 1TB, I installed debian on it, everything is after sftp, I don't need any more. Works for 4-5 years. No errors on the disks. I also added an emergency power supply in the form of a buffer power supply with a 7Ah battery.
    I am thinking about adding the SUV500MS disk to the system, because there is a mini PCI-Express connector on this board, apparently it will work.
    Watch out with this goodram because you can quickly fall down if you beat it 24 hours a day, if you want a budget, it's better Goodram IRDM :)
  • #6 18483633
    snake3d
    The disk is not equal to the disk, the batch is not identical, the materials of manufacture may be with a defect, anyone can fall. It's worth having a replication / backup.
    I've had mostly Seagate drives for over 20 years. One on probably 30 has already fallen to me unexpectedly, 20GB was a long time ago, I recovered the data by switching the board from another. I replaced the 1.5TB 7-year-old, recently based on info smart. And a week ago I bought another Seagate for my home NAS with 12 drives, all Seagate.
    If you have important data, you need to protect yourself, always.
  • #7 18483642
    Bojleros
    Rate: 24
    I have Asrock on J2900 with 16GB of RAM and I'm pissed off because sftp doesn't reach 33MB / s ... sshd is choking on cpu. Equipment sufficient, but sometimes annoying.
  • #8 18483662
    kassans
    Level 32  
    Help: 130
    Rate: 412
    Łukasz_W wrote:
    This seagate is just for a photo ;) ultimately there will be 4x 2tb WD Black with a DELL sticker server versions.
    DVO wrote:
    thinklient will not fit 4 disks here I can insert a sata controller in PCI and have more than 4 disks
    noyo wrote:
    I had a Goodram C40, CL100, CX100, CX200, CX400 are working. There is only Xigmanas on this SSD, I have a copy of the configuration, so if it falls, I change it and in 30 minutes I have us still working
    krzbor wrote:
    As I wrote, the SilentiumPC power supply will fall :) . OMV supports attached USB NTFS drives and sharing them via SMB?
    Bojleros wrote:
    That's why I chose such a platform, instead of a celeron, I can throw in I5 or I7 and it will slide nice :)
    Overall, I didn't think this post would cause such a big response.
  • #9 18483663
    chemik_16
    Help: 75
    Rate: 128
    for me it also started on a 1-core celeron s775, after a few years it ended like this; p
    We are building our own NAS server We are building our own NAS server
    ps: there was also something smaller in the meantime - but never finished:
    the case from the hp t5720 has holes like itx, soldered cooling and wio; p
  • #10 18483680
    dvo
    Rate: 11
    In thinclient, you throw the SSD inside, and you take the warehouse outside.
  • #11 18483690
    chemik_16
    Help: 75
    Rate: 128
    how thinclient is only from usb3.0 era, 22nm and less. The older ones are uninteresting in terms of power consumption / performance, usually they have a controller with a TDP similar to the cpu ;)
    from the recently fashionable armów odroid on the exynos pulls gigabit after spanking & 250MB / s sata. Unfortunately, they both have usb3.0 and not pcie.
    As long as the android-box on Amlogic will also work, there are quite a dynamically developed Linux distro for that.
  • #12 18483743
    kassans
    Level 32  
    Help: 130
    Rate: 412
    chemik_16 wrote:
    And what transfers do they have when raid? what if the processor will download 5w if it can't handle the raid? :D
  • #13 18483751
    Karaczan
    Help: 869
    Rate: 1127
    Do not use only EXT4 on NTFS shared drives.
    NTFS support is more resource-intensive than EXT4.
    The CPU will take some weight off and the transfers will increase!
  • #14 18483757
    pawelr98
    Help: 413
    Rate: 1155
    I have a Seagate ST4000DM000 since mid-2013.
    It cost half the WD of the same capacity.
    It works ? It works.
    I have two more 7200.12 1TBs that are about 9-10 years old. Also flawless.
    The most powerful are Hitachi / HGST disks.
    Very durable.
    In 2017 I bought 6 Hitachi 2TB deckchairs from 2010-2011.
    There was a 3-year warranty I took it, it sits in the RAID6 array, so it's enough to replace the disk and rebuild.
    To this day, they work around the clock, have a tested smart and are fine.
    The key to keeping your disks in good condition is:
    - decent power supply
    - good cooling
    - continuous work without parking
    I haven't invested much in my platform.
    Instead of a housing with places for disks, I simply bought long steel angles in a construction site.
    The whole front has been pulled out from the inside and in its place angles are screwed on.
    In the photo it was covered with dust, but later it was dismantled and cleaned.
    In general, the angles work well, but it is difficult to disassemble and remove the discs a bit because they are pressed between the angles. Even after unscrewing the screws, they can still stay in place and it takes a little force to pull them out.
    Or play loosening screws on nearby disks.
    That's why I clean it less often.
    Someone may ask why I didn't use an energy-efficient platform instead of a full ATX with a separate GPU.
    Well, the problem was that the i3 550 board did not want to work with the SAS HP P400 card, which I use to support RAID 6.
    It just kept crashing on startup.
    And the 870A-USB3 board with the Athlon II X2 250 was ready.
    It runs on Debian 8.2.0 x64 and uses samba.
  • #15 18483769
    chemik_16
    Help: 75
    Rate: 128
    the problem was that the i3 550 board wouldn't work with the SAS HP P400 card,
    it was not enough to plug in SMbus? so far all SAS / raid controllers worked for me after this action.
    Eventually I ended up with 2x dell H310 reprogrammed to regular LSI with IT mode. I have a software raid.
    After the action, when after replacing 1 disk from the matrix, the hardware raid cleaned the rest of the disks for me - thank you ;)
  • #16 18483839
    m0n5t3r
    I am at the stage of building NAS. Mine consists of the following parts:
    - micro atx housing with acer-veriton m4 (about PLN 35 + shipping) but cool housing because with screwless mounting of disks + reworking the connection to the front panel
    - biostar j1800 board (PLN 80 + shipping)
    - ram 2x4gb ddr3 (from the drawer :) )
    - intel pro 1000 ct network card (PLN 30 + shipping)
    - seagate IronWolf 3tb * 2 disks (2 * PLN 450 for new ones)
    - fanless power supply from the old miniitx housing + printed mounting (free)
    Everything works on Xpenology. The network card was needed to update to the latest software version without any combination.
  • #17 18483862
    Łukasz_W
    Help: 633
    Rate: 658
    Very durable.
    - good cooling
    Gentlemen, I am speaking from the level of experience, colleagues from the forum who deal with this plot will say the same.
    Yes, any disk can crash, but you can work with any other.
    However, when it comes to Seagate, its current products are at a very low level.
    In RAID6, and any other, more than two disks can fail at once.
    Let me not be groundless:
    Last week's Seagate 5TB, damaged two heads out of eight and a sawn surface.
    Seagate on Tuesday, IronWolf 3TB, head damage so far, but the previous IronWolf caught a drink on four of the six surfaces.
    For the sake of balance, two Toshiba with RAID1 working in a Dell server (yes, but someone invented it) with a UPS.
    We are building our own NAS server We are building our own NAS server We are building our own NAS server
    As I mentioned, this is your data and you can either consider good advice or not.
    Please only then do not set up the topic in the "data recovery -> disk click, I replaced the electronics but still clicks".
    HEX SERWIS
  • #18 18483872
    VSS
    Help: 5
    Rate: 261
    Intel Celeron G1840 is a tiled stove. If you count the power consumed by the disc and disks, it turns out that it will cost you PLN 30-40 per month. After a year, it would be possible to buy a NAS. I have two ZYXELs at home: NAS520 and NAS325v2. They are very stable - FTP, cloud, torrent, backup works. This takes an average of 8W.
  • #19 18484112
    kassans
    Level 32  
    Help: 130
    Rate: 412
    Łukasz_W wrote:
    How about DELL branded WD Black drives?
    VSS wrote:
    But I am still addicted to 2 disks and the zyxell operating system, here I can throw 4 disks, and do whatever I want with them, I can share USB disks, run virtualki. If there is no power, I change the processor, replace the ram and continue the NAS. My us starts during the hours I use it so it doesn't download 40w 24/7 [
  • #20 18484131
    Łukasz_W
    Help: 633
    Rate: 658
    In general, I do not recommend brands, because it is not known if they have software modifications.
    HEX SERWIS
  • #21 18484247
    dvo
    Rate: 11
    Wd black is not for PC?
    RED AND RED PRO is designed for us
  • #22 18484249
    Bojleros
    Rate: 24
    You must have messed up something. I have had contact with LSI / Awago based controllers and occasionally HP controllers for a long time. I had no problems. Currently in us I have a debranded Fujitsu on LSI Megaraid and no problems. HW raid is used on mainstream seed to spare any cpu that would be eaten by softraid. The second can for backups has the usual softraid, but this is also because these disks can be transferred to any Linux machine, assemble the matrix and extract the data from the backup. There is no controller that can fall down and leave me with nothing.
    Additionally, in Linux it is implemented with FUSE so the code to handle this filesystem is not part of the kernel itself. As for me, this is enough for the occasional copying of something from a dead Windows or a USB flash drive and nothing else.
    It should also be remembered that if the matrix was not overloaded, the rebuild will cause an abnormal load on the disks, which may lead to further failures of disks that seemed to be healthy.
    Sometimes vendors of enterprise-class equipment use vendor locking at the firmware level.
    And when you do RAID you leave some unused space at the end of the disk? Sometimes the series of disks ends or the supplier changes and the disk differs in size by a few percent, so replacing the damaged one may fail ...
  • #23 18484262
    kassans
    Level 32  
    Help: 130
    Rate: 412
    I had a few delli brought from abroad sat WD Black branded on DELL worked in the raid. Perhaps Dell wanted more performance without increasing costs, for example SAS drives
  • #24 18484963
  • #25 18485005
    sat2
    Help: 10
    Rate: 11
    Haven't you thought about setting up Debian and configuring it as a NAS? Personally, I have such a server with three disks (8TB, 6TB and 6TB) + TV with DVB-T and DVB-S and it works great. No problems for several years. You can also log in and start downloading some files. A very convenient solution.
  • #26 18485113
    kassans
    Level 32  
    Help: 130
    Rate: 412
    Debian = fun, Xigmanas set up in 30 minutes, web access available, will I do that in Debian too? ;)
  • #27 18485240
    krzbor
    Help: 42
    Rate: 1072
    I read an article on the future of "clouds". The author wrote that it would grow and decrease at the same time. Grow - because the current processing centers will be even larger, and decrease because small private (home) clouds will be created. I agree with it. Now we don't just think of the NAS as an external network drive. You need a computer that works 24h, where NAS is only one of its functionalities. My server has 4TB disks and it is slowly filling up.
    Do @ Gravastar1986, - the largest volume is data that is a security copy of home computers (my and my family's), including movies and photos. Monitoring videos also take up space. Data collected from a smart home also weighs its own.
  • #28 18485403
    Hetii
    Rate: 420
    These H81M boards are nice, I had such a long time with the I5 4460, but after changing to ryzena it went as HTPC equipment.
    Some time ago I bought a FAS270 matrix for the entire PLN 50, inside 14 disks as in the picture below.
    For now, it is dusting and I wonder what to do with it, because I do not copy the Internet.
    I also heard that apparently the drives are dedicated to this model, so when they fall, they are still wiped.
  • #29 18485601
    dvo
    Rate: 11
    Honestly, it doesn't go crazy with this internet backup ... you have 14 disks of 147GB each, which is roughly 4TB. ;)
    By the way, last year I focused on security and all devices back up to my server.
    I have 2 x 4tb and now I wish I had bought two 6. Laptops and smartphones hold a lot of valuable data.
    You will probably eat me, but I do not have drives fastened to RAID. They work separately and I only set up a backup machine for my important data. So I have copies of my photos on two disks.
  • #30 18485764
    kassans
    Level 32  
    Help: 130
    Rate: 412
    Thanks to the large number of disks, it has higher performance :D I do not keep photos, but I have a lot of music that I will not find on YouTube spots ...
    Hetii are SAS drives, so you can buy them without any problem :)
The discussion revolves around building a personal NAS (Network Attached Storage) server, particularly focusing on the challenges and solutions related to hardware selection, software options, and data management. Users share their experiences with various NAS systems, including FreeNAS and Xigmanas, highlighting the importance of compatibility with NTFS drives and the need for reliable hardware. Several users recommend specific motherboards, processors, and RAM configurations, emphasizing low power consumption and efficient performance. Concerns about data redundancy, backup strategies, and the reliability of different hard drive brands are also discussed, with users sharing their preferences for Seagate, WD, and Hitachi drives. The conversation touches on the benefits of using Linux-based systems like OpenMediaVault and the practicality of using older hardware for NAS setups.
TL;DR: Home-built NAS boxes on used x86 hardware push 110 MB/s over Gigabit [Elektroda, chemik_16, post #18498979]; “If you have important data, you need to protect yourself, always” [Elektroda, snake3d, post #18483633] Stick to mirrored drives, quality PSU, and scheduled backups.
Why it matters: Solid throughput plus disciplined backup keeps DIY storage both fast and safe.
• Typical Gigabit SMB speed: 80-110 MB/s [Elektroda, Bojleros, post #18497446] • Idle power draw: ARM 8-12 W [Elektroda, VSS, post #18483872]; x86 25-60 W [Elektroda, Karaczan, post #18483388] • FreeNAS needs ≥8 GB RAM; Xigmanas runs on 4 GB [Elektroda, kassans, post #18489038] • Used Celeron G1840 board + 8 GB RAM bought for PLN 120 [Elektroda, kassans, post #18483414] • Rebuilds stress disks; keep offline backup alongside RAID [Elektroda, Bojleros, post #18484249]
5. Do I need ECC RAM for ZFS?
FreeNAS recommends ECC, yet several builders run ZFS on non-ECC for years without corruption [Elektroda, kassans, post #18488221] Expect slightly higher risk; keep verified backups.
7. How can I hit 100 MB/s over Gigabit?
Use single-disk EXT4 or RAID5, enable Jumbo Frames, and avoid FUSE-NTFS. Users reported 110 MB/s on three-disk RAID5 with LSI controller [Elektroda, Bojleros, post #18497446] A single large file copies fastest.
8. How do I access the NAS securely from the Internet?
Combine DDNS with VPN (WireGuard or OpenVPN). Builders tunnel RDP over SSH to avoid exposed ports [Elektroda, kassans, post #18488221] Disable default admin accounts and enforce key-based logins.
9. What’s the safest drive configuration?
Mirror (RAID1) or ZFS mirror protects from one failure. RAID6 survives two but rebuild is stressful and can trigger more failures [Elektroda, Bojleros, post #18484249] Keep an external backup, not just RAID.
10. How do I back up the system boot disk?
Clone the SSD/USB stick with AOEMI or dd to another drive, then store the image on the data pool [Elektroda, procsa, post #18848034] Re-imaging takes under 10 minutes.
11. Can hardware RAID cards fail badly?
Yes. After swapping one drive a controller wiped the whole array [Elektroda, chemik_16, post #18483769] Prefer HBA in IT mode plus software RAID where disks stay readable on any machine.
12. How to set up Xigmanas in three steps?
  1. Flash the ISO to USB, boot and pick ‘Install on SSD’. 2. Create ZFS pool, enable SMB. 3. Save config backup off-box. Total time ≈30 minutes [Elektroda, kassans, post #18485113]
14. What edge cases should I plan for?
During RAID rebuild disk load jumps 3-5× normal and SMART-OK drives can die [Elektroda, Bojleros, post #18484249] Maintain spare drives and leave 1-2 % unallocated so smaller replacement disks fit.
15. How noisy should cooling be?
Replace stock coolers with large low-RPM towers; after switching to SilentiumPC Fera only disks are audible [Elektroda, kassans, post #18483414] Keep HDD temps 30-40 °C to extend life.
