Network in a single-family house divided into LAN / WLAN - installation equipmen
aleksander_a 47010 9
How should I arrange a home network with a radio internet link, three wired rooms, a NAS, and Wi‑Fi so that every socket can access the LAN?
Yes—put the router first on the antenna/WAN side, because with a single ISP IP address a switch cannot sit before it; the router does NAT and exposes only one public address [#14202852][#14202877] From the router, use a switch to distribute Ethernet to the three room cables, and any device plugged into the LAN can reach the NAS as long as everything is on the same internal network [#14202866][#14202874] The Wi‑Fi should come from an access point in the room you choose, not from the attic [#14202866][#14203238] Gigabit is worth it for a NAS, since 100 Mbit/s limits transfers to around 12 MB/s, while gigabit can reach 70–80 MB/s in typical use [#14203238] If the house is large, consider multiple access points, preferably powered via PoE over the twisted pair so they do not need separate power sockets [#14203238]
  • #1 14202796
    aleksander_a
    I'm moving home soon and I'm at the stage of equipping my home with equipment - selecting devices to create a network.
    Some facts: RJ cables routed from the attic to 3 rooms in the house (separate cable for each room); the internet will be radio.
    As for what I would like to connect, it looks more or less like the diagram below.
    As for the functionality, I would like there to be internet and local area network in every socket - I would like to be able to read data from NAS in every room with a socket. In addition, of course, a WiFi network.
    Now my questions:
    - does a network planned in such a way make sense? Will I be able to access the NAS from any device connected to the socket?
    - my biggest doubts are where I should use the switch and router; when it comes to the WiFi signal, only from room 3 - I do not want to emit a signal from the attic
    I don't mean a specific piece of equipment (brand, etc.), but the idea itself.
    Any comments / advice are appreciated.
    Thank you in advance and best regards,
    Olek
  • #2 14202827
    przeqpiciel
    Help: 285
    Rate: 238
    There may be eggs :)
    Instead of a switch at the top, I would give a router, and instead of a router I would give another switch - if there were no + Access Point sockets for Wi-Fi distribution
  • #3 14202852
    lesławek
    Level 32  
    Help: 190
    Rate: 295
    If your ISP has a single IP address (and you probably do) then you can't use a switch on the WAN side. The first device from the antenna side must be a router, it has a NAT implementation and will assign private addresses to the rest of the devices, and will map many internal network addresses to a single address on the WAN side.
  • #4 14202855
    przeqpiciel
    Help: 285
    Rate: 238
    In addition, the router will, in a sense, separate you from what would be on the other side. So a bit of security :) I would, without a doubt, put my own router right behind the antenna - but it's just me :)
  • #5 14202866
    m.jastrzebski
    Help: 679
    Rate: 865
    Now my questions:
    Olek
    Where you have drawn a switch to be a router, a cable will suffice, it does not need to have WiFi on board.
  • #6 14202874
    cosmoo
    Rate: 20
    With the appropriate router configuration, the network would work in this configuration, but a better solution is to replace the router with the switch as written by its predecessors. Virtually every router has a built-in switch, so there will be no problem.
    Star-TECH
    Powiat, Garwolin, 08-400
  • #7 14202877
    lesławek
    Level 32  
    Help: 190
    Rate: 295
    przeqpiciel wrote:
    In addition, the router will, in a sense, separate you from what would be on the other side. So a bit of security :) For me, I would put my own router right behind the antenna - but it's just me :)
    Well, you just have to, because behind the antenna you have only one address and only one device will work, because either you have the address entered in the contract, or it is assigned automatically, and other devices connected to the switch will either report an IP address conflict or will not work at all. As for security, you are right because only the router is directly visible from the Internet, while other devices "see" the Internet, but are not seen.
  • #8 14203196
    aleksander_a
    Cool!
    Thanks to everyone for the answers!
    That's what I wasn't sure about - whether it was a router or a switch at the beginning.
    One more thing - is it worth investing in Gigabit? After the local network, it will probably 'make a difference' ...
    Regards,
    Olek
    m.jastrzebski
    Help: 679
    Rate: 865
    aleksander_a wrote:
    Cool!
    This was what I wasn't sure about - whether it was a router or a switch at the beginning.
    Regards,
    Olek
    IMHO is worth it.
    You have NAS.
    You're gonna keep photos and videos there, I guess right?
    I do not know what NAS, but what I have, on the 1GB network when copying to the NAS, it reaches several dozen (70-80) MB / s.
    With a 100mbit network, you will not exceed 12MB / s although you bought the fastest NAS
    Depending on what you want to copy, send, stream, take and count on this network.
    You can buy a 100mbit router, even with one LAN socket, and a gigabit switch with as many cables as you need. And preferably with a small margin.
    If the house is large (I see 2x TV), one radio will not cover the whole house via WiFi.
    Then consider that the switch should have exit PoE. You pull several cables to various remote parts of the house, where you connect the AP that is powered by the twisted pair. Access Point will then work at 100mbit, but WiFi is still enough.
    Then the access points do not need a power socket, they are small, neat, some kind of ceiling, etc.
  • #10 14203362
    aleksander_a
    m.jastrzebski wrote:
    IMHO is worth it.
    You have NAS.
    Exactly as you write - a NAS for photos, vacation videos, etc - will be QNAP's dual slot.
    As for AP, that's a good idea :)
    Thanks everyone for all the advice!
The discussion revolves around setting up a network in a single-family house with both LAN and WLAN capabilities. The user plans to connect multiple devices, including a NAS, through RJ cables routed to three rooms, with internet access provided via radio. Key points include the necessity of using a router at the start of the network to manage IP addresses and ensure security, as switches cannot be used directly on the WAN side. Recommendations suggest investing in Gigabit equipment for better data transfer rates, especially for NAS usage, and considering Access Points (AP) for improved WiFi coverage throughout the house. The user is advised to use a Gigabit switch and potentially PoE for powering APs without needing additional outlets.
