Top Craft Pressure Washer: Engine Alternates On/Off When Lance Not Used - Causes & Solutions
koszerny 9714 13
Why does my Top Craft pressure washer keep switching the motor on and off when the lance is not used, and how can I fix it?
The symptoms point to a faulty pressure valve or pressure-operated cutoff switch in the pump, which can make the washer cycle on and off when the trigger is released [#16472124] There may be a second mechanically linked part that automatically cuts power when pressure rises, even if the visible switch is only the manual on/off switch [#16481022] The recommended next step is to disassemble the white housing and inspect the components connected to the wires, because the exact valve/switch location is still unclear from the photos [#16481022] The thread also notes that this type of washer can use a Karcher-style pump with a pressure valve [#16472145]
  • Pressure washer cycles due to faulty unloader or pressure switch
    #1 16472039
    koszerny
    Rate: 37
    Hello, I have a Top Craft pressure washer. I have a problem, because it works weird, i.e. when taking the water it is ok, but when the lance is not used, the engine turns on and off alternately. If I do not turn it off, then after a long while the engine works non-stop and then I can only disconnect the plug from the socket. What could this be caused by? How to fix it ?
    I will mention that the washer does not leak so it should be ok.
  • #2 16472124
    REMUR.
    Help: 143
    Rate: 255
    These are symptoms of a malfunctioning pressure valve.
  • #3 16472145
    koszerny
    Rate: 37
    It is a washer with a karcher pump inside where there is a pressure valve.
  • #4 16472155
    REMUR.
    Help: 143
    Rate: 255
    Unscrew the washcloth and insert some photos, it will be easier to locate.
  • #5 16472175
    koszerny
    Rate: 37
    a few photos, I don't know if I should include anything else Top Craft Pressure Washer: Engine Alternates On/Off When Lance Not Used - Causes & Solutions Top Craft Pressure Washer: Engine Alternates On/Off When Lance Not Used - Causes & Solutions Top Craft Pressure Washer: Engine Alternates On/Off When Lance Not Used - Causes & Solutions Top Craft Pressure Washer: Engine Alternates On/Off When Lance Not Used - Causes & Solutions Top Craft Pressure Washer: Engine Alternates On/Off When Lance Not Used - Causes & Solutions
  • #6 16472206
    REMUR.
    Help: 143
    Rate: 255
    Personally, I do not know this type, I drew conclusions from my washcloth. It would be better if you went out into the daylight, take photos in higher resolution of the elements to which the wires are connected.
  • #7 16478819
    koszerny
    Rate: 37
    that's all I can do without unscrewing
    Top Craft Pressure Washer: Engine Alternates On/Off When Lance Not Used - Causes & Solutions Top Craft Pressure Washer: Engine Alternates On/Off When Lance Not Used - Causes & Solutions Top Craft Pressure Washer: Engine Alternates On/Off When Lance Not Used - Causes & Solutions Top Craft Pressure Washer: Engine Alternates On/Off When Lance Not Used - Causes & Solutions Top Craft Pressure Washer: Engine Alternates On/Off When Lance Not Used - Causes & Solutions Top Craft Pressure Washer: Engine Alternates On/Off When Lance Not Used - Causes & Solutions Top Craft Pressure Washer: Engine Alternates On/Off When Lance Not Used - Causes & Solutions
  • #8 16479032
    REMUR.
    Help: 143
    Rate: 255
    1.Where the other end of the marked wire is connected.
    2. Where is the cable with a plug connected.
    It is true that there are fragments in the photos, but nothing can be deduced from them.
  • #9 16479037
    koszerny
    Rate: 37
    it is this cable that ends with a plug
  • #10 16479080
    REMUR.
    Help: 143
    Rate: 255
    Before we "start" undressing, take a look at this topic Link . A similar washer, and maybe a fault.
  • #11 16479747
    koszerny
    Rate: 37
    in my case it is different because everything works except switching off when a given pressure is reached
  • #12 16480097
    REMUR.
    Help: 143
    Rate: 255
    It means that you haven't even bothered to look, you're not helping. Wear of an element can manifest itself with various symptoms. Disassembly will not miss you anyway,
    Read more # 14
  • #13 16480404
    koszerny
    Rate: 37
    I looked and read
    REMUR. wrote:
    It means you haven't even bothered to look
    "After pressing the trigger on the lance, the washer did not turn on" so it's not what I was doing
    to ensure that this chemical valve is used as a pressure valve
    REMUR. wrote:
    Read more # 14
    a very nice description, only that this valve is nowhere to be found or hidden
    when it comes to the switch, it is an ordinary switch that only cuts off or gives voltage to the motor
  • #14 16481022
    REMUR.
    Help: 143
    Rate: 255
    koszerny wrote:
    unless this chemical valve is used as pressure valve
    That's why you were supposed to undress and check, because so far we don't know anything.
    That's right, every device should have such a "switch", it is used to manually control the washer. However, there may be a second, mechanically connected
    something that will automatically cut the power when the pressure rises. And the next step will be to disassemble the white housing, photos are welcome (full focus).
The discussion revolves around a malfunctioning Top Craft pressure washer that experiences intermittent engine operation when the lance is not in use. Users suggest that the issue may stem from a faulty pressure valve, particularly since the washer is equipped with a Karcher pump. Several participants recommend inspecting the internal components, including the pressure valve and electrical connections, to identify the cause of the problem. The need for clearer photographs of the internal wiring and components is emphasized to facilitate troubleshooting. Some users reference similar issues in other models, indicating that disassembly may be necessary to diagnose the fault accurately.
