Laptop Samsung NP300E5C: Reset BIOS, Disable Secure Boot, UEFI & CSM for Win 7 Install
kozak1224 32727 12
How can I reset the BIOS on a Samsung NP300E5C that keeps rebooting after switching from UEFI to CSM and no longer lets me enter Setup?
Remove both the main battery and the CMOS battery, then short the CMOS battery contacts for 10–15 seconds to discharge any capacitors; this should reset the BIOS back to UEFI and let the laptop boot again [#19074254] One reply also suggested disconnecting the AC adapter and main battery first, then holding the power switch for about 30 seconds before shorting the CMOS battery socket contacts [#16473723][#16473910] The short should be made across the contacts in the battery socket, using a small metal item if needed [#16473910][#19240216]
  • BIOS resets at Samsung logo after enabling CSM
    #1 16473591
    kozak1224
    Rate: 9
    Hi
    In a laptop with Win 8.1 I wanted to install Windows 7. Unfortunately, despite disabling secure boot, the flash drive and the disc still could not boot, even though they were working on another computer. So I changed UEFI in bios to UEFI and CSM. It didn't do anything. After setting up the CSM itself (now I know it was a bug :) ) the laptop turns on until the bios and samsung logo are loaded and a reset occurs. From the very beginning, the F2 key does not enter the bios, and now, when it is needed, it still does not work :( . I took out the bios batteries to reset it for over 40 minutes, but to no avail. I am looking for reset jumpers, but I cannot locate them on the board (probably not there). I need help getting him back on his feet.
    Once again I took out the battery, now I will wait longer. I hope that some capacitor still holds the bios before the reset, and a longer time without a battery will cause a reset.
    Is there any other option to reset the bios or enter its settings?
    The motherboard of this laptop is Lampard 14/15 int rev 1.0 and the laptop itself is probably Samsung NP300E5C-A02PL (because all stickers are already illegible).
  • #2 16473723
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    After disconnecting the power (power supply and battery), hold the switch for half a minute. If it does not help, remove the cmos battery and shorten its contacts.
  • #3 16473801
    kozak1224
    Rate: 9
    Thank you for your answer.
    I do not fully understand, I am supposed to short-circuit the plus and minus of the battery or socket itself. The board itself does not have any jumpers that I could close.
  • #5 16474080
    kozak1224
    Rate: 9
    Unfortunately, shorting the contacts did not help, because after starting the bios, there is a reset.
  • BIOS reset attempt yields no display or startup sounds
    #7 16474115
    kozak1224
    Rate: 9
    Over 10 sec, but I will try again. I fired it up now with no bios battery, it boots up but no screen or any sounds.
    I kept a good 30 seconds of the battery socket shorted with a metal screwdriver, but unfortunately all the time after turning on the computer, only the bios and reset are charged.
    I found the jumpers probably, plugged the 1 and 2 pins together, but no effect.
  • CMOS reset restored UEFI boot mode
    #8 19074254
    remiss
    Hi kozak1224,
    Three years later, it looks like I made the exact same mistake on my Samsung NP300E5C-AF4FR.
    I have a GPT disk with a dual-boot (Lubuntu and Windows 10). Everything was fine until I tried to install Windows 7 from a Legacy USB key (now I know I shouldn't, I should have used a UEFI key...). I changed from UEFI to CSM . Now my computer keeps rebooting for ever. It says "[F2] for Setup [F4] for Recovery", and then immediately reboots. Again and again. The function keys have no effect (I tried them all, from F1 to F12). I also tried ESC and DEL, with no success. I am unable to boot on any of the two systems. I am unable to enter the BIOS and restore to UEFI. I also removed the hard disk, but my computer keeps rebooting, even without a hard disk.
    Did you have any success repairing your system? How did you solve your problem?
    [Edit] Solved. I removed the main battery and the CMOS battery, and shorted the connectors for 10-15 seconds to ensure that eventual capacitors were discharged. The BIOS was automatically reset to UEFI, and I was able to boot Lubuntu again. Hope this helps.
  • #9 19239953
    aliamad
    @remiss
    Hi remiss,
    I have exactly the same problem (following the same process with a dualboot). Can you please let me know how can I short the connectors ? I would like to try if this solution work for me.
    Many thanks
  • #10 19240216
    remiss
    Hi aliamad,
    You can use any small metallic item. Personally I used a simple paperclip - un trombone, in French ;) - that I bent so that it can touch both contacts on the motherboard. A small 5-cents coin might do the job too, if you manage to insert it in the place where the battery should be.
  • #11 19240447
    aliamad
    Many thanks remiss!
    It seems that it is not working with my issue, but thank you for your answer. I will try again, maybe I am doing it wrong.
    Thanks again
  • #12 19241774
    kindlar
    Help: 919
    Rate: 1622
    If you have access to a second laptop, remove the drive from yours and insert it into the other one. Install the system to the first boot, then swap disks again. Complete the installation on your laptop.
  • #13 19248441
    aliamad
    Thank you kindlar, I will try this solution !
    Cheers,
The discussion revolves around troubleshooting a Samsung NP300E5C laptop that fails to boot after attempting to install Windows 7. The user initially disabled Secure Boot and switched the BIOS settings to UEFI and CSM, but encountered continuous resets and an inability to access the BIOS. Various suggestions were made, including disconnecting power and battery, shorting the CMOS battery contacts, and using metallic items to bridge connections. Despite these attempts, the user faced persistent issues, prompting inquiries about effective methods to reset the BIOS. Another participant shared a similar experience and successfully resolved their issue by removing both the main and CMOS batteries and shorting the connectors. Additional advice included using a second laptop to install the operating system on the hard drive before reinserting it into the original device.
