How to Set Up USB Booting for Windows 10 on Laptop: BIOS Configuration Guide
8304 10
How do I make my Samsung NP350E7C-S05 PL laptop boot from a Windows 10 USB drive when the BIOS only shows disk and DVD?
Disable Secure Boot in the BIOS and check the boot list with the pendrive connected before startup; if the USB still does not appear, recreate the Windows 10 installation media with Microsoft’s tool [#16428682] [#16428669] [#16428699] The thread suggests the problem may have been the installation media itself, since the user later remade it and then managed to continue [#16428699]
  • #1 16428667
  • #2 16428669
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Can you give the model of a disc or computer or do you have to guess?
    After starting up with the pendrive connected, you still can not see it on the list?
  • #3 16428674
  • #4 16428682
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Have you disabled a secure boot in your bios?
    You did not answer for this:
    > After starting up with a pendrive connected, it still can not be seen on the list?
  • #5 16428699
  • #6 16428707
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    How can "badly download" since the program from MS creates a carrier for installation by itself?
  • #7 16428722
  • #8 16429108
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Then give the one you have in your bios. Only before you have to read it somehow, and you will need a system for that.
  • #9 16429151
  • #10 16429177
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Do not have a recovery partition with W10 on the disk?
  • #11 16429199
The discussion revolves around setting up USB booting for Windows 10 on a Samsung NP350E7C-S05 PL laptop. The user initially faced issues with the BIOS not recognizing the USB drive, only showing options for disk and DVD. Suggestions included checking if secure boot was disabled and ensuring the Windows media was correctly created. After re-creating the installation media, the user encountered a problem where the installation did not prompt for a product key, but later discovered that the system could retrieve the key automatically. However, they faced difficulties with partition formatting during installation, as existing partitions could not be formatted from the installer.
