Samsung NP300E5E: Looped Reset on Power On After BIOS Changes - Win8 to Win7 Boot Options
Diegoxol 7251 15
  • #1 15323702
    Diegoxol
    Hello!
    I tried to reinstall win8 to win7. After setting in the bios the possibility of booting other media, i.e. turning off these locks, after rebooting, the laptop turns on, the Samsung logo appears with a bar at the bottom F2 BIOS F4 BOOT something there and after 2 seconds there is a restart with such a characteristic tick. Everything loops and the same thing happens.
    Bios restart (30 minutes without battery) did not help.
    Somewhere I found that the switch may be broken, but replacing it did not help. I have no ideas what to do because the warranty has already expired and I would like to try to fix it myself.
  • #2 15323714
    miecho18
    IT specialist
    Help: 3087
    Rate: 2775
    For reprogramming the BIOS chip in an external programmer.
  • #3 15323716
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1538
    It worked properly on the previous system?
  • #4 15323747
    Diegoxol
    On Windows8 it worked without any problems. It's just that this system is still there because I haven't had time to install anything yet.
  • #5 15323795
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1538
    Diegoxol wrote:
    on win8 it worked without a problem. It's just that this system is still there because I haven't had time to install anything yet
    Then reinstall it.
  • #6 15323817
    Diegoxol
    but I can't because the computer keeps resetting ;)
  • #7 15324134
    miecho18
    IT specialist
    Help: 3087
    Rate: 2775
    After removing the drive, it also resets?
  • #8 15324288
    Diegoxol
    Yes. It also restarts without the disk.
  • #9 15324332
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1538
    Reset CMOS to start with.
  • #10 15324347
    Diegoxol
    I just wrote that I was doing a BIOS reset by removing the battery for 30 minutes. Unless there is some other way to do it?
  • #11 15324426
    miecho18
    IT specialist
    Help: 3087
    Rate: 2775
    In post # 2, I wrote what to do first.
  • #12 15324513
    Diegoxol
    I understand that I will not do it at home and I have to go to a service? I read that you need a programmer that is not cheap :)
  • #13 15324528
    miecho18
    IT specialist
    Help: 3087
    Rate: 2775
    That's right.
  • #14 15324629
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1538
    Rather.
    You need a programmer, adapter, batch and soldering skills.
  • #15 15324671
    Diegoxol
    Do you know what the price of such a service is?
  • #16 15324909
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1538
    Probably 150 PLN in Wawa.
✨ The discussion revolves around a Samsung NP300E5E laptop experiencing a boot loop after attempting to change BIOS settings to switch from Windows 8 to Windows 7. The user reports that after modifying the BIOS to allow booting from other media, the laptop fails to boot, displaying the Samsung logo briefly before restarting. Attempts to reset the BIOS by removing the battery for 30 minutes did not resolve the issue. Suggestions from other users include reprogramming the BIOS chip, checking if the laptop worked properly with the previous system, and resetting the CMOS. The user expresses concern about the need for specialized equipment and skills for BIOS reprogramming, indicating a potential service cost of around 150 PLN for professional help.
