Focus MK1 2001 Sedan 1.8 Zetec 115HP: Identifying A/C Compressor Issues, Fuses & Relays
10272 10
Why does the A/C compressor in a 2001 Ford Focus MK1 1.8 Zetec with manual air conditioning not start, and what should I check first?
If the refrigerant circuit is empty, the compressor will not start, so the first check should be system pressure and whether there is a leak [#16475129] You can verify this by removing the valve cap and checking the pressure with a gauge; if needed, have the system tested on a machine at a service station [#16475155] If the system is empty, look for the leak with nitrogen [#16476014] If pressure is present and it still does not engage, check the A/C fuse/relay, blower fan speeds, compressor clutch coil resistance, the thermal switch on the compressor, and clean the compressor connectors [#16474937]
  • #1 16474920
    123nowy
    Help: 55
    Rate: 101
    Check first if you have a factor in the system.
  • #3 16474937
    Foxtrott
    Help: 253
    Rate: 944
    For fuses, look here:
    http://www.autogenius.info/en/ford-focus-mk1-security/, if they differ, check each fuse in turn.
    Do you have all "gears" of the supply fan?
    Check the resistance of the A / C clutch coil and the thermal switch located on the compressor. Clean all connection blocks from the compressor.
  • #4 16475104
    123nowy
    Help: 55
    Rate: 101
    If it is empty, the compressor will not start. You must start by checking the pressure.
  • #6 16475155
    Foxtrott
    Help: 253
    Rate: 944
    Do you have a factor in the system, you can check in a very simple way - unscrew the protective cap from the valve and connect the pressure gauge, if you do not have it, you can gently try to push the valve valve - as a last resort - protect your eyes and skin !! , but it's better to drive up to the station and check the pressure on the machine - you should not count for it when you promise to return to "filling" after eliminating the faults.
  • #7 16475220
  • #8 16475242
    123nowy
    Help: 55
    Rate: 101
    That it was filled a year ago does not mean anything.
  • #9 16476007
  • #10 16476014
    123nowy
    Help: 55
    Rate: 101
    Well then nitrogen and look for a hole
  • #11 16476938
The discussion revolves around diagnosing A/C compressor issues in a 2001 Ford Focus MK1 Sedan with a 1.8 Zetec 115HP engine. The user reports that the compressor does not start, and previous attempts to check fuses and relays were hindered by missing documentation. Responses suggest checking the refrigerant pressure, as an empty system prevents compressor activation. Users recommend using a pressure gauge to assess the system and advise looking for leaks if the refrigerant is low. The user ultimately expresses frustration with the costs associated with repairs and considers the vehicle too old for further investment.
