Focus mk1 - The driver's door central locking does not work
Pontonek79 8460 14
Why does the driver’s door central locking on a Ford Focus Mk1 not work from the remote while the other doors still lock and the key locks the whole car?
The fault was in the comfort module contacts; cleaning them with contact cleaner restored the central locking, and the module is located behind the storage compartment [#16862036] Before that, the suggested checks were the wiring harness in the driver’s door-to-body grommet and the lock motor/wires at the driver’s door [#16857022][#16857298] The symptoms also pointed to the driver’s door side, because the passenger side still locked the whole car while the driver’s door did nothing from the remote [#16857145]
  • #1 16856980
    Pontonek79
    Rate: 9
    Hello, I will move once again, the central topic in focus is a little different than you describe, namely a week ago the central stopped working does not close the door from the driver (from the remote control) the rest of the door ok but the key closes the whole car another curiosity at the same time the flap opening button fell the one on the board) works with the remote control and now what to do with it what has become a comfort module or something else. and to the complete the passenger window button works but does only one thing opens the window even set to the closing position (functional button) HELP SOMETHING SOMETHING SOMETHING
  • #2 16856988
    wrobel000
    Rate: 23
    Welcome. The best solution to connect to your computer. Or first check the cable harness from the computer to the door. There may be a short circuit there, which is why the computer is freaking out.
    Moderated By T5:
    3.1.11. Do not send messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
  • #3 16856998
    Pontonek79
    Rate: 9
    It was connected to zero computer errors
  • #4 16857003
    wrobel000
    Rate: 23
    And could you use the computer to control the window that does not close or close the car?
  • #5 16857009
    Pontonek79
    Rate: 9
    I did not try and just checked if the errors are
  • #6 16857013
    wrobel000
    Rate: 23
    If you have a computer, try it. If you don't drive, look at the cable harness.
  • #7 16857022
    andrzej20001
    Help: 1578
    Rate: 6666
    @ wrobel000 let a friend come down to earth with this computer.
    @ Pontonek79 Check the harness at the driver's door-bodywork grommet, but the lock motor might have fallen. Remove the flap button and measure with a test tube.
  • #8 16857043
    Pontonek79
    Rate: 9
    Well ok with this engine but the central key works
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6428
    First, see if the central works by pushing the passenger and driver handles from the inside.
  • #10 16857145
    Pontonek79
    Rate: 9
    From the passenger works the whole car closes the driver door from the driver nothing happens, only the door closes
  • #11 16857250
    andrzej20001
    Help: 1578
    Rate: 6666
    With the key you close the door with the key
  • #12 16857252
    Pontonek79
    Rate: 9
    Well, but then the central works closes the whole car and locks the locks
  • #13 16857298
    andrzej20001
    Help: 1578
    Rate: 6666
    Check these wires
  • #14 16857596
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4180
    To the author - the next post without any specific information about checking in the car I will reward accordingly.
  • #15 16862036
    Pontonek79
    Rate: 9
    I started cleaning the contacts in the comfort module with a contact cleaner. The central working comfort module is located behind the storage compartment. It helped me.
The discussion revolves around a malfunction in the central locking system of a Focus MK1, specifically the driver's door, which does not respond to the remote control while other doors function correctly. The user also reports issues with the window control and a fallen flap opening button. Responses suggest checking the cable harness for short circuits, using a diagnostic computer to identify errors, and inspecting the comfort module located behind the storage compartment. Cleaning the contacts in the comfort module has been noted as a potential solution that resolved the issue for one user.
TL;DR: On this Focus Mk1 thread, 1 of 1 confirmed fixes was contact‑cleaning the comfort module; "It helped me." Located behind the storage compartment/glovebox. Symptoms included driver door not locking by remote, odd window/tailgate behavior. [Elektroda, Pontonek79, post #16862036]
Why it matters: This FAQ helps Focus Mk1 owners quickly diagnose and fix driver‑door central locking that fails while other doors still work.
What are the telltale symptoms when the driver’s door central locking fails on a Focus Mk1?
Typical symptoms: the remote won’t lock the driver’s door, but other doors work. The dash tailgate button may stop. The passenger window switch may only open, not close. The key can still lock the whole car. These signs appeared together in the reported case. [Elektroda, Pontonek79, post #16856980]
Where is the comfort module on the Focus Mk1?
The comfort module sits behind the storage compartment or glovebox area. Access it by removing the compartment, then inspect and clean the connectors. This location was stated by the owner who resolved the issue. [Elektroda, Pontonek79, post #16862036]
How was the problem fixed in the thread?
The owner cleaned the comfort‑module contact pins with a contact cleaner. After cleaning, the central locking worked again. The concise report was: “It helped me.” This is the only confirmed fix in the discussion. [Elektroda, Pontonek79, post #16862036]
Will a diagnostic scan always show a fault for this issue?
No. In this case, a scan showed zero errors even while the driver’s door wouldn’t lock via remote. Electrical contact corrosion or broken wires can disrupt functions without setting codes. The thread explicitly notes 0 fault codes. [Elektroda, Pontonek79, post #16856998]
Could a broken wire in the door grommet cause these symptoms?
Yes. A damaged wire in the driver door–to–body harness can cause locking and window anomalies. An experienced member advised checking the harness at the grommet and considering the lock motor. “Check the harness at the driver’s door‑bodywork grommet.” [Elektroda, andrzej20001, post #16857022]
Is the lock motor a suspect if only the driver’s door won’t lock from the remote?
It can be. One helper suggested the lock motor might have failed alongside advising wiring checks. Before replacing parts, inspect wiring and contacts, then test the actuator if accessible. Replace the motor only after basic checks. [Elektroda, andrzej20001, post #16857022]
My passenger window switch only opens, not closes—related to central locking?
It can be related. The reported case had that switch opening only, not closing, while the driver’s door remote lock failed. Shared power or signal issues from the comfort module or harness can link the symptoms. Fixing contacts restored locking in that case. [Elektroda, Pontonek79, post #16856980]
The dash button for the tailgate stopped working—what should I check first?
Check the comfort‑module connectors for oxidation and reseat them. In the thread, the tailgate dash button failed alongside the locking issue, and contact cleaning at the comfort module resolved the main problem. Inspect wiring next if symptoms persist. [Elektroda, Pontonek79, post #16856980]
How can I quickly verify if the central system still responds inside the car?
Use the interior door handles. One helper suggested pushing the driver and passenger handles from inside to see if the central system reacts. This quick test helps distinguish actuator and signal issues. Compare driver and passenger responses. [Elektroda, Strumien swiadomosci swia, post #16857124]
How do I clean the comfort‑module contacts? (3‑step How‑To)
  1. Remove the storage compartment/glovebox to access the comfort module.
  2. Unplug connectors and spray contact cleaner on pins and sockets.
  3. Let it dry, reconnect firmly, and test locking and switches. This exact cleaning restored operation in the thread. [Elektroda, Pontonek79, post #16862036]
What tools or materials do I need for the fix?
You need trim tools to remove the storage compartment, and an electronics contact cleaner. The owner reported cleaning the comfort‑module contacts with a contact cleaner, after which the central locking worked again. Keep lint‑free wipes on hand. [Elektroda, Pontonek79, post #16862036]
Can I use a diagnostic computer to command windows or locking as a test?
Yes, if your tool supports active tests. A participant suggested using a computer to try closing the window and locking the car, or else inspecting the harness. Active tests can isolate module versus wiring faults. [Elektroda, wrobel000, post #16857003]
What is the “comfort module” referred to in this thread?
It is the vehicle’s convenience controller that handles central locking and related functions. In this Focus Mk1 case, it sits behind the storage compartment. Cleaning its contacts restored the locking system in the reported fix. [Elektroda, Pontonek79, post #16862036]
Any quick stat or edge‑case to keep in mind?
Stat: one scan showed 0 fault codes during the failure, proving DTCs may be absent. Edge‑case: intermittent wiring breaks at the door grommet can mimic module faults. Check wiring even when scans are clean. [Elektroda, Pontonek79, post #16856998]
