Hyundai I30 2009: Aktivierung der OEM Daytime Running Lights DRL - Bezpieczniki Niemieckie
srbastek 12645 5
  • DRL integrated in BCM, external module may be needed
    #1 16479164
    srbastek
    Rate: 38
    Witam.
    Posiadam Hyundai I30 fd 2009r. Samochód sprowadzony z Niemiec (tak wiem, płakał jak sprzedawał :P ). Jest puste miejsce na bezpiecznik, po włożeniu nic się nie dzieje (to znaczy światła mijania się nie włączają). Poczytałem trochę na: service.hyundai-motor. com, ale nic mi to nie daję ;/
    Spoiler:
    Inspection
    1.
    The daytime running unit is integrated in the BCM (A).
    2.
    Check that the light operate according to the following timing chart.
    (2)
    Operation condition
    a.
    DRL ON
    ALT L signal and IGN2 signal input
    b.
    DRL operation
    ALT L ON
    The head lamp relay and tail lamp relay ON.
    c.
    DRL OFF
    Tail lamp Relay ON.
    Head Lamp relay OFF.
    4.
    If the daytime running light is not operated well, Inspect the connector and terminals to be sure they are all making good contact.
    If the terminals are bent, loose or corroded, repair them as necessary, and recheck the system.
    If the terminals look OK, go to step 4.
    5.
    Make these input tests at the connector by using ETM.
    If any test indicates a problem, find and correct the cause, then recheck the system.
    If all the input tests prove OK, the I/P (Instrument panel) junction box must be faulty; replace it.
    Jest sposób na włączeniu fabrycznych świateł dziennych?
    Czy pozostaje tylko moduł zewnętrzny.
    Pozdrawiam.
  • #2 16479285
    piotrekwoj1
    Help: 947
    Rate: 3433
    Probably through a service computer.
  • #3 16482575
    srbastek
    Rate: 38
    Ok, I searched and searched for a pattern:
    The cable with I / PD (pos. 17) is plugged in, but the second mass with I / PG is empty, if I understand correctly, all you have to do is release the cable to ground? Although according to photo71 the weight is next to the lamps, but probably just plug anywhere?
  • #4 16506165
    srbastek
    Rate: 38
    Question for experts :)
    A friend in my fuse measured the output from the DRL fuse (ground, blue M) and is not connected (no piii) and I was thinking about adding my fuse before the rest (purple B).
    There is a relay inside the fuses, according to the diagram there should be nothing. BCM seems to be responsible for that
    piotrekwoj1
    Help: 947
    Rate: 3433
    Let it to someone who overwhelms you because you do more harm than good. You make measurements in fuses with a meter set for continuity of the circuit. You'll burn something in a minute and it'll come out of it.
  • #6 16506300
    srbastek
    Rate: 38
    It was measured after disconnecting the battery. This transition / workaround what I have to think about will do with someone overwhelmed (electronics, but cars do only for themselves after collecting all the information), but I wanted to advise whether it makes sense at all.
    Is it better to add an external module / relay.
