Passat B6: Set Halogen Lights as DRLs using VCDS in Auto Position, Bixenon & Cornering Lights
mateuszkaizer 4989 1
  • #1 16581881
    mateuszkaizer
    Rate: 15
    Hello, I would like to set the halogen lights as daytime running lights so that they work on the machine, i.e. on the switch in the Auto position. Currently, when it is on, nothing lights up during the day and bixenon at night. It also has cornering lighting and could also work as a daylight. I have a VCDS. Thank you for your help
    michu14031
    Help: 12
    Rate: 38
    You are able to do so, but in this case the halogens will glow after releasing the manual.
    As for the settings, you do it with the long coding of the bordnetz driver, but not in all of them you can set it depending on whether it has 13, 17.27 30 bytes
    channel 09
    byte 0 bit 3 or 4 i don't remember now
    byte 17 bit 4
    lighting
    byte 23 bit 4 and you choose from the list what to shine as a floodlight, whether halogen or, for example, road light
