Activating Daytime Running Lights (DLR) on VW T5 2010 with VCDS - Facelift Lamps, P21W Bulbs
Oszech 14757 8
  • #1 16400262
    Oszech
    Rate: 34
    how to activate daytime running lights in VCDS? The car has facelift lamps with P21W bulbs to perform this function, but I don't know how to activate them, the Bortnetz version is 7H0 937 086 B, do you still need to replace the lighting switch? At the moment I have 3 positions + rear fog.
    Regards
  • #2 16400454
    andrzej20001
    Help: 1578
    Rate: 6666
    Try to hold the turn signal handle turned on right towards you "on long flash" and turn on the ignition for 5 seconds. In octavia 2, passat works
    Deactivate left.
  • #3 16400475
    miro.nasz
    Help: 88
    Rate: 171
    Hello!
    I would connect daytime running lamps in a very simple way, namely:
    I would install LED lamps because they consume very little power if there were no additional lamps in the car. In the permanently mounted lamps I would only change the light bulbs to LEDs. I would disconnect the power of these lamps and connect as described.
    Connecting additional lamps. I would use a relay with contacts connected to the power supply. When the coil gets voltage it disconnects them.
    I would connect daytime running lamps to the power contact.
    Relay power supply is connected with voltage after turning the key. Relay coil one end to ground and the other to the dipped beam. When the key is turned to start the engine, the daytime running lights are on when the dipped headlights are switched on, the daytime running lights go out.
    To make my life easier, I would additionally use a relay to turn off the car interior lights and the lights turn off after a few seconds.
    Just insert it between the ignition supply and the relay from the additional lights, connect properly. The effect is that I start the engine and after a few minutes the lights come on. / There are a lot of different time switches on the Internet / you can use them /. As I described, I don't have to think if my lights are on. Regards Miro. Ours
  • #4 16400534
    Oszech
    Rate: 34
    To be honest, I would prefer to stick to the original, especially since I think it is a matter of proper coding.
  • #5 16401874
    miro.nasz
    Help: 88
    Rate: 171
    Hello!
    What I described is for a car in which the computer no longer works and the installation was already buried. Here I would risk changing the bulbs to LEDs but after factory settings on the computer. Changing the bulbs may show an error.
    If I can get the data to my computer, I'll give it to you.
    Regards Miro. Ours
  • VCDS byte 23 bits for T5 DRL control
    #6 19889989
    kroolpaw
    Rate: 22
    I drive a VW T5 FL at work for business and I was also annoyed by the daytime running lights that were on non-stop. One day I couldn't stand it and by trial and error (checking every byte in the long coding) I found a way. In my car sits the central electrics module 7E0937090D. Ordinary H4 lamps with direction and 21W daytime running lights.
    And this is how I did it:
    Central electrical system -09
    Long coding -07
    Byte -23
    Bit - 6 (daytime running lights Scandinavia)
    Bit - 5 (daytime running lights active together with position lights)
    Bit - 4 (US daytime running lights with handbrake)
    Bit - 3 (daytime running lights with halogens)
    Bit - 2 (daytime running lights in dipped headlights)
    This is what it looks like with me, maybe someone will find it useful. In the registration certificate I have the 2016 year of production but it is 100% the last release of the T5 FL. Activating or deactivating the DRLs with the handle (indicator + hold on high beam) does not work.
  • #7 20540287
    Bart_71
    Level 19  
    Help: 7
    Rate: 24
    Hello and welcome,
    I have a vw Transporter T5 FL 2010 raw with comfort module 7h0937086b.
    Can I activate the daytime running lights?
    In Byte 23 it is not possible to activate the lights.
    Need to replace a module?
  • #8 21698902
    saviq81
    >>20540287 and how the topic died, did anything manage to backfire
  • #9 21699019
    kroolpaw
    Rate: 22
    More on the subject I can't help. To the fact that I set the daytime running lights like this is just a coincidence. Maybe the module with my numbers is just coded that way.
Discussion about enabling daytime running lights on a VW T5 facelift using VCDS and the central electrics module. The original question asks whether DRLs can be activated in coding with module 7H0 937 086 B and whether the light switch must be replaced. One reply suggests a generic ignition/indicator lever trick, but the main useful answer comes from a T5 FL owner who found DRL options in Central Electrics coding: Byte 23, bits for Scandinavia DRLs, DRLs with position lights, US DRLs with handbrake, DRLs with halogens, and DRLs in dipped headlights. Another user with module 7H0937086B reports that Byte 23 cannot be used to activate DRLs and asks if the module must be replaced. The thread ends without a confirmed retrofit solution for that specific module, only the observation that some modules may already be coded differently from factory.
