TomTom Navigation - Polish Map Update for Imported Renault Model with SD Card & Start 25 Device
Michal1561 14724 16
How can I restore the Poland map on a Renault TomTom Carminat SD card after TomTom Home seems to have removed it, and can I copy it from another TomTom Start 25 device?
To get the Poland map back, restore it from your backup in `My Documents\TomTom`; if needed, unzip the Poland folder to the map tab. [#16479552][#16479724] If you do not have a backup, the practical options are to buy the map again through TomTom Home or contact TomTom support to recover it. [#16479451][#16482427] For this Carminat model, only the original map is supported, so copying a map from the Start 25 is not a valid solution. [#16480655][#16481510] TomTom Home is said to update maps rather than delete them, so the missing Poland map likely was not removed by the update itself. [#16481154]
  • #1 16479409
    Michal1561
    Level 4  
    My problem looks as follows. I wanted to update the map of Poland via the SD card removed from Tom Tom's navigation (model attached). At the very beginning I installed the TomTom Home 2 program and updated the map but it turned out that it was a map of France because the Renault was imported from there. After importing to Poland, the map of Poland was uploaded to the card. After the update, the map of Poland was completely removed and the changes took place only in the map of France. I also have the second tomtoma navigation - start 25 which has been updated twice by usb and there is no problem with it. Maybe thanks to this navigation you can somehow copy the map of Poland to the SD card. My goal is to re-map Poland (it does not necessarily have to be updated). Thank you for your answer. Greetings.
    • TomTom Navigation - Polish Map Update for Imported Renault Model with SD Card & Start 25 Device 20170516_081415.png (188.78 KB) You must be logged in to download this attachment.
  • #2 16479451
    koala106
    Help: 471
    Rate: 1240
    If you do not have a backup, there are two options: purchase of a new map by Tomtom Home or contact with the tomtoma service - as Poland was bought, it will help you recover.
  • #3 16479549
    Michal1561
    Level 4  
    I did a backup but I do not know where she signed up
  • #4 16479552
    koala106
    Help: 471
    Rate: 1240
    My documents - Tomtom and search there
  • #5 16479600
    Michal1561
    Level 4  
    Well, I found and how to restore it
  • #6 16479724
    koala106
    Help: 471
    Rate: 1240
    Unzip the Poland folder to the map tab.
  • #7 16480477
    Michal1561
    Level 4  
    Unfortunately, I did not find such a folder. This map costs 180 PLN. Is downloading from pirated pages punished in any way?
  • #8 16480522
    japycz321
    Help: 92
    Rate: 141
    Yes, it is. Call TomTom, let them map you with which device you have sold.
  • #9 16480655
    koala106
    Help: 471
    Rate: 1240
    Here you have nothing to combine, because only the original will go.
  • #10 16480756
    Michal1561
    Level 4  
    I do not understand one more thing. The map of Poland was bought by TomTom home and just removed when updating ?!
  • #11 16481154
    koala106
    Help: 471
    Rate: 1240
    This is not possible. Tomtom Home does not delete the map, it only updates it so that the program will remove - you would have to try hard.
  • #12 16481337
    Michal1561
    Level 4  
    Oh, so this map may have been downloaded from other sources than TomTom home
  • #13 16481510
    koala106
    Help: 471
    Rate: 1240
    In this Carminata model there is no other option than the original.
  • #14 16481543
    Michal1561
    Level 4  
    So we are dealing with the original map which itself has been removed ?!
  • #15 16482017
    koala106
    Help: 471
    Rate: 1240
    Apparently ... In addition, on the first screen you have a map in the old version - you probably have not upgraded - version 9.05 is a few years old nice ma ...
  • #16 16482369
    Michal1561
    Level 4  
    The photo I made before the update. So, I just had to buy the original map for PLN 180 ?!
  • #17 16482427
    koala106
    Help: 471
    Rate: 1240
    If you had the original - turn to the Tomtom website and help, if not, buy the map.
The discussion revolves around a user experiencing issues with updating the Polish map on a TomTom navigation device after importing a Renault model from France. The user initially updated the map using TomTom Home 2, but the Polish map was replaced with the French map. Despite having a backup, the user struggled to restore the Polish map. Responses suggested contacting TomTom support for assistance, purchasing a new map, or checking the backup location. It was clarified that TomTom Home does not delete maps during updates, and the user may need to buy the original map for 180 PLN if it was not properly backed up or restored.
