[Solved] TomTom Renault Megane: Updating Maps & Adding Polish Language - Step-by-Step Guide
Mrkacper 33693 8
  • #1 17195768
    Mrkacper
    Level 4  
    Rate: 32
    Hello, I have a question because in the new car there is no map of Poland and language. Is there any way to get these maps and how to upload them
  • #2 17195883
    sanfran
    Help: 963
    Rate: 3004
    If it's a new car, why not turn to the manufacturer?
    Unauthorized burial may invalidate the warranty.
  • #3 17195939
    Mrkacper
    Level 4  
    Rate: 32
    But this car is from 2009 and imported from Germany
  • #4 17195971
    coperfild
    Help: 291
    Rate: 1697
    What is the Carminat liveze navigation with sd slot or Carminat itself?
  • #5 17196021
    Mrkacper
    Level 4  
    Rate: 32
    The one with the sd card slot
  • #6 17196431
    dziakoni
    Rate: 25
    if you navigate tomtom download map 1005 for carminata soft suitable and acoustic pad
    Added after 6 [minutes]:
    navcore
    http://www10.zippyshare.com/v/48983587/file.html
    activator here
    http://www89.zippyshare.com/v/cXy8ExLb/file.html
    program to extract "ttgo.bif"
    http://www26.zippyshare.com/v/86582093/file.html
    the map is here
    http://forum.dvhk.to/showthread.php?t=484443&page=2
    DESCRIPTION OF ACTIVATION
    1. The 4 GB SDHC card is needed. We format the card into the Fat32 file system.
    2. We go with the card to the car, put it in Carminata and fire.
    3. Remove the card, go to the PC and insert into the card reader.
    4. We check if the "loopdir" folder was created on the card. The "loopdir" folder can also be copied from the original Carminat card.
    5. We run the program on the PC to extract the "ttgo.bif" file from the "loopdir" folder. How to do it, described in the Info.txt file.
    6. Copy a folder with map files from the PC disk to the card.
    7. Copy the activator file "FastActivate.exe" and the file "ttgo.bif" to the card
    8. We activate the map. Description of activation in the activator's Info.txt file (ACTIVATION OF A MAP).
    9. Copy the navcore card, ie the contents of the folder: SE_Navcore_8.842_Carminat_TomTom.
    10. We remove the file: ttgo.bif and FastActivate.exe from the card.
    11. We go with the card to the car, it should work.
    Moderated By T5:
    3.1.1. Do not share illegal material or other information that violates the law.
    Warning.
  • #7 17199460
    Mrkacper
    Level 4  
    Rate: 32
    Okay, I'll try a lot thanks
  • #8 17199711
    Sniezynka
    Help: 199
    Rate: 841
    And out of curiosity, I ask how the legality of such an operation?
    After all, in-car navigation often has lifetime map updates.
  • #9 17207115
    Mrkacper
    Level 4  
    Rate: 32
    I bought maps from the original page and I played
The discussion revolves around updating the TomTom navigation system in a 2009 Renault Megane, specifically to add Polish maps and language support. Users suggest contacting the manufacturer for assistance, although one user clarifies that the vehicle is an imported model. The conversation includes technical details about the Carminat navigation system with an SD card slot. A step-by-step guide is provided for downloading and installing maps, which involves formatting a 4 GB SDHC card, extracting necessary files, and copying map data. Concerns about the legality of such updates are raised, with one user confirming they purchased maps from the official website.
