Location Search: BMW E39 Sedan 1998 2.5 124 kw Blower Fuse F76, No Power on Fan Regulator
Serwo2 9789 1
  • #1 16479470
    Serwo2
    Rate: 13
    Hello, I can not find the blower fuse F76 I checked in the trunk behind the storage space under the passenger rug under the hood and nothing else. It's only behind the storage compartment probably the F75 50A supplying the radiator fan. The thing is that there is no plus on the interior fan regulator yellow-green wire pin 2 going further along the wire, I noticed that it goes to the contacts of the relay which I do not see in the diagram, there is already at the input of the relay contact the color of the wire red blue also without power I have no idea where he keeps walking. According to the F76 scheme, it is powered by the F113 80A fuse under the rug which is good I have no idea if this is a rare version that this fuse does not have to be somewhere but where to look for it?
  • #2 16521414
    DoctorCar
    Level 19  
    Help: 37
    Rate: 123
    Remove the glove box and there should probably be 2 MAXI fuses next to each other in the relays 40A is a blower
