BMW E70 Cabin Blower Not Working: Possible Motor Damage or Worn Brushes - Fuse Check Done
greymetal 11331 3
  • #1 16466372
    greymetal
    Hello. Suddenly the blower in the cabin stopped working. All these fuses on the front and rear are good. It can be assumed that the motor is most likely damaged or the brushes are worn? If so, I would order the blower earlier so that the mechanic would replace it for me right away.
    Regards - Zbyszek.
  • #2 16466435
    Maurycy147
    Help: 9
    Rate: 14
    The blower resistor might have broken much more often than the motors.
  • Seized blower impeller freed with WD-40
    #3 16466929
    greymetal
    Thanks alot. We will check and let you know.
    Added after 15 [hours] 7 [minutes]:
    When the resistor "runs down", the blower is unstable, it turns off, and even turns on when the car is closed. For me, the blower turned off absolutely. We took it out and found the impeller to turn strangely hard. I thought it was some kind of brake invention, but after applying WD-40, it started spinning loosely. After applying power, it also started working properly. We put it all together and it's great. I just wonder how long ;)
    I greet everyone - Zbyszek.
  • #4 18395834
    Karol-mbr107
    Rate: 16
    I need to remove the fan from the blower in the x5 e70 because it squeaks ... need to remove the cockpit at the front or not? Can you write how to get to him? Better advice from a person what she was doing than to take half the car apart and tear off half the hooks
    Thanks in advance Karol
