Vocational examination without a technical school in a given educational field o
Peanutbutter66 19656 6
  • #1 16483138
    Peanutbutter66
    Hello ,
    I am curious whether I can take a vocational exam for, for example, computer science, eg E12, without studying at a technical school in the field of IT technician. Is it possible with a course available on the market or simply an institution? I am currently studying electronics technician, but I would love to pass IT professional exams.
  • #2 16483200
    kiss39
    Help: 397
    Rate: 636
    To take the vocational examination, the applicant must submit the Declaration and the school leaving certificate in advance - these are the regulations.
  • #3 16483225
    Peanutbutter66
    I understand that I will be able to pass them after graduation anyway? And where can such a declaration be submitted?
  • #4 16483236
    kiss39
    Help: 397
    Rate: 636
    Rather, it is impossible without a secondary school diploma in a technical profession, in this case an IT technician
  • External exam requires documented work experience or school enrollment
    #5 16488920
    bodzio507
    Level 30  
    Help: 22
    Rate: 579
    You could take such an exam externally if you worked in the profession and had a documented probably 3 years of work experience.
    Otherwise, you can take the exam while studying at a technical or post-secondary school.
    You submit the declaration to OKE, but to submit it, you must have a certified completion of school education or work experience.
    The school leaving certificate has nothing to do with passing a qualification.
    Usually, such a certificate is obtained after passing all qualifications.
  • #6 16490360
    Peanutbutter66
    And will I be able to pass these exams after, for example, studying programmer?
  • #7 16494319
    bodzio507
    Level 30  
    Help: 22
    Rate: 579
    Studies are a different level. Rather, you will not be allowed to take these exams because you will not have the basics.
    And why do you need technical college qualifications, if you will have adequate higher qualifications?
The discussion revolves around the eligibility to take vocational examinations, specifically in the field of computer science (E12), without attending a technical school for IT technicians. It is clarified that a secondary school diploma in a technical profession is generally required to take these exams. However, individuals with documented work experience (approximately three years) in the relevant field may qualify to take the exam externally. The submission of a declaration to the appropriate educational authority (OKE) is necessary, along with proof of education or work experience. The conversation also touches on the distinction between vocational qualifications and higher education qualifications, suggesting that higher education may not provide the foundational knowledge required for vocational exams.
