Configuring Linksys BEFSX41 Router for Orange Biznes DSL Service with Livebox Business 131 Modem
Suchy86CK 5901 12
How do I configure a Linksys BEFSX41 to work behind an Orange Biznes DSL Livebox Business 131 modem/router?
Configure the BEFSX41 WAN side to get its address automatically from the Livebox instead of using the public 46.171.90.46/30 settings, because the Orange “private IP addresses” block means the Livebox is acting as the router and should hand out a LAN address like 10.0.0.x via DHCP [#16486035] On the computer/server interface connected to the router, turn on DHCP and set DNS to automatic; the 169.254.x.x address you saw means no DHCP lease was received [#16486132][#16486134] If you want to test the line, connect a PC directly to the Livebox and check whether it gets connectivity, then run `ping onet.pl`, `ping 8.8.8.8`, and `ipconfig /all` to see what address was assigned [#16485659] Also verify the Livebox LEDs and that the cable is plugged into the correct LAN port, because the thread showed the Internet worked only after moving the cable to another port [#16486172]
  • #1 16485437
    Suchy86CK
    I have the Orange Biznes DSL service.
    Devices, starting from the modem, are connected in this way:
    Livebox Business 131 modem> Linksys BEFSX41 router> server> switch> other computers
    I had to change my router and now I need to configure it.
    Data from Orange:
    Private IP addresses. Network: 10.0.0.0
    Mask: 255.255.255.0
    Gateway: 10.0.0.1
    Preferred DNS addresses: 194.204.159.1
    Alternate: 194.204.152.34
    Public IP addresses Web: 46.171.90.44
    Mask: 255.255.255.252
    Gate: 46.171.90.45
    Parameters of the network connection with the router (on the server):
    IP: 10.0.0.2
    Mask: 255.255.255.0
    Gateway: 10.0.0.1
    Preferred DNS: 194.204.159.1
    Alternate DNS: 194.204.152.34
    Parameters of the network connection with the switch (on the server):
    IP: 192.168.0.200
    Mask: 255.255.255.0
    Gate:
    Preferred DNS: 127.0.0.1
    Alternate DNS: 10.0.0.1
    Everything worked fine on these parameters, now I have a second router and there is a problem with its configuration.
    I choose: Static IP
    IP: 46.171.90.46
    Gate: 46.171.90.45
    DNS 1: 194.204.159.1
    DNS 2: 194.204.152.34
    IP router: 10.0.0.1
    Gateway: 255.255.255.0
    I'm turning off DHCP
    Unfortunately, the internet does not work after this treatment. I followed the instructions from another router (Draytek) ftp://ftp.draytek.pl/POMOC/Gotowe_przyklady/WAN/Ethernet/Ethernet_DSL.pdf
    Can anyone help me configure this router properly?
    bogiebog
    Help: 2569
    Rate: 1530
    Connect the computer to the LB so that there is internet. Run cmd.exe, type
    ping onet.pl
    ping 8.8.8.8
    ipconfig / all
    show printouts.
  • #3 16485949
    Suchy86CK
    As I understand it, I need to connect my computer to Livebox and configure the connection with these parameters on the computer:
    IP: 46.171.90.46
    Gate: 46.171.90.45
    LucekB
    Help: 143
    Rate: 137
    Yes, try this addressing on your network card, if it doesn't work, check the address from the machine to be sure.
    Do you have an entire address list for this service?
  • #5 16486027
    Suchy86CK
    This data is printed from Orange:
    Network: 10.0.0.0
    Mask: 255.255.255.0
    Gateway: 10.0.0.1
    DNS addresses
    Preferred: 194.204.159.1
    Public IP addresses
    Web: 46.171.90.44
    Gate: 46.171.90.45
    From the gate, it can be concluded that there are two addresses assigned to the service, but they are not given in the documents (I concluded that these are 46 and 47 because 45 is the address of livebox).
    bogiebog
    Help: 2569
    Rate: 1530
    Network: 10.0.0.0
    Mask: 255.255.255.0
    Gateway: 10.0.0.1
    It rather means that the LB works like a router, on the van it has a public IP on the DHCP LAN,
    connect the computer to the LB and have the LB assign an IP to the computer automatically.
  • #7 16486118
    Suchy86CK
    I connected without configuration (only DNS is entered, with DNS to auto also does not work):
    Microsoft Windows [Version 6.1.7601]
    Copyright (c) 2009 Microsoft Corporation. All rights reserved.
    C: \ Users \ user> ping onet.pl
    The ping command cannot find the onet.pl host. Check the name and try again
    Be.
    C: \ Users \ user> ping 8.8.8.8
    Test 8.8.8.8 with 32 bytes of data:
    Reply from 46.171.87.46: The target host is unreachable.
    Ping statistics for 8.8.8.8:
    Packets: Sent = 4, Received = 4, Lost = 0
    (0% loss),
    C: \ Users \ user> ipconfig / all
    Windows IP configuration
    Host name. . . . . . . . . . . : user-Computer
    Primary DNS suffix. . :
    Node type. . . . . . . . . . . . : Hybrid
    IP routing enabled. . . . . . . : No
    WINS Proxy server enabled. . . . : No
    Mobile broadband card. Mobile broadband connection
    e:
    Condition of the media. . . . . . . . . . .: Media disconnected
    Connection-specific DNS Suffix:
    Description. . . . . . . . . . . . . . . : Dell Wireless 5550 HSPA + Mini-Card Networ
    k Adapter
    Physical address. . . . . . . . . . : 02-80-37-EC-02-00
    DHCP enabled. . . . . . . . . . : No
    Auto configuration enabled. . . . : Yes
    Wireless LAN adapter Wireless LAN connection 2:
    Description. . . . . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter
    Physical address. . . . . . . . . . : 08-11-96-F0-A5-69
    DHCP enabled. . . . . . . . . . : Yes
    Wireless LAN adapter Wireless LAN connection:
    Connection-specific DNS suffix: bullish
    Description. . . . . . . . . . . . . . . : Intel (R) Centrino (R) Advanced-N 6205
    Physical address. . . . . . . . . . : 08-11-96-F0-A5-68
    Ethernet adapter Local connection:
    Description. . . . . . . . . . . . . . . : Intel (R) 82579LM Gigabit Network Connecti
    he
    Physical address. . . . . . . . . . : D4-BE-D9-08-FC-6D
    Local connection IPv6 address. : fe80 :: 499a: 1e56: 2c91: 2180% 13 (Preferred)
    IPv4 address. . . . . . . . . . . . . : 169.254.33.128 (Preferred)
    Subnet mask. . . . . . . . . . : 255.255.0.0
    Deafult Gateway. . . . . . . . . . :
    The DHCPv6 IAID. . . . : 299155161
    DHCPv6 Client DUID: 00-01-00-01-20-45-D4-E7-D4-BE-D9-08-FC-6D
    DNS servers. . . . . . . . . . . : 194.204.159.1
    194.204.152.34
    NetBIOS over Tcpip. . . . . . . : Activated
    Ethernet tab Bluetooth network connection:
    Description. . . . . . . . . . . . . . . : Bluetooth device (personal network)
    Physical address. . . . . . . . . . : 74-DE-2B-99-07-F1
    Isatap Tunnel Card. {1554AB50-CD28-439F-86D1-E91F4A342646}:
    Description. . . . . . . . . . . . . . . : Microsoft ISATAP tab
    Physical address. . . . . . . . . . : 00-00-00-00-00-00-00-E0
    Teredo Tunneling Pseudo-Interface Card:
    Description. . . . . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
    C: \ Users \ user>
    I also connected with this configuration:
    IP: 46.171.90.46
    Gate: 46.171.90.45
    Be.
    (0% loss),
    e:
    k Adapter
    he
    IPv4 address. . . . . . . . . . . . . : 46.171.90.46 (Preferred)
    Subnet mask. . . . . . . . . . : 255.255.255.252
    Deafult Gateway. . . . . . . . . . : 46.171.90.45
    194.204.152.34
    Tunnel card 6TO4 Adapter:
    Description. . . . . . . . . . . . . . . : Microsoft 6to4 tab
    IPv6 address. . . . . . . . . . . . : 2002: 2eab: 572e :: 2eab: 572e (Preferred)
    194.204.152.34
    NetBIOS over Tcpip. . . . . . . : Disabled
    C: \ Users \ user>
    Heinzek
    Help: 554
    Rate: 494
    he
    You didn't turn on DHCP
    You also tried to set the static IP to 10.0.0.2
    mask 255.255.255.0
    gateway 10.0.0.1
    bogiebog
    Help: 2569
    Rate: 1530
    Turn on DHCP in the computer, in the properties of the network adapter ipv4 should be
    ip get auto
    dns get auto
  • #10 16486146
    Suchy86CK
    Be.
    Reply from 192.168.43.238: The target host is unreachable.
    The request timed out.
    Packets: Sent = 4, Received = 2, Lost = 2
    (50% loss),
    e:
    k Adapter
    he
    Auto-configuration IPv4 address. . . . : 169.254.33.128 (Preferred)
    DNS servers. . . . . . . . . . . : fec0: 0: 0: ffff :: 1% 1
    FEC0: 0: 0: ffff :: 2% 1
    FEC0: 0: 0: ffff :: 3% 1
    Isatap Tunnel Card. {DC6DC7B0-F43A-4E14-9FE7-973C6811BC0C}:
    Description. . . . . . . . . . . . . . . : Microsoft ISATAP # 2 tab
    C: \ Users \ user>
    I also set up:
    10.0.0.2
    255.255.255.0
    10.0.0.1
    Also to no avail.
  • #11 16486167
    bogiebog
    Help: 2569
    Rate: 1530
    Suchy86CK wrote:
    I also set up:
    10.0.0.2
    255.255.255.0
    10.0.0.1
    Also to no avail.
    is ping 10.0.0.1 working then?
    no ? call orange support, let them figure it out
    Yes ? ping 8.8.8.8 working? ping onet.pl works?
    Heinzek
    Help: 554
    Rate: 494
    Write or take photos of how the LEDs on this livebox are lit and where you connected the computer.
  • #13 16486196
    Suchy86CK
    pings 10.0.0.1, 8.8.8.8, onet.pl do not work.
    The Status, ADSL, and Com LEDs are green.
    The IP LED flashes green.
    The SFP, WIFI, and Maintenance LEDs are off.
    I connected the computer to the same place to which the 0/0 LAN router was connected
    I switched the cable to LAN 0/1 and now the internet works to a directly connected computer, so in total you can forgive an additional router. One problem remains. There is internet on the server, but not on other computers in the network. Do you have any idea how to do it?
    The server has 2 network cards, here is their configuration:
    IP: 10.0.0.2
    Mask: 255.255.255.0
    Gateway: 10.0.0.1
    IP: 192.168.0.200
    Mask: 255.255.255.0
    Gate:
    The rest of the computers are assigned an address via DHCP mp. 192.168.0.50
    I already found it. Routing and remote access were disabled on the server. Everything works. Thanks for the help.
The discussion revolves around configuring a Linksys BEFSX41 router for use with the Orange Biznes DSL service, connected through a Livebox Business 131 modem. The user initially faced issues with internet connectivity after replacing their router. Various configurations were suggested, including setting static IP addresses and enabling DHCP. The user confirmed that while the server had internet access, other connected computers did not. Troubleshooting steps included checking ping responses to the gateway and public DNS, as well as verifying LED indicators on the Livebox. Ultimately, the user was able to establish internet access on a directly connected computer but needed further assistance to extend connectivity to other devices on the network.
