Windows 10 Home: Disabling Grouped Icons on Taskbar - Finding Option for New User, KP
krzychu82 29418 2
  • #1 16485830
    krzychu82
    Rate: 25
    Hey,
    I am a new user of windows 10, I really do not like how I have grouped icons on the bar. I tried to disable it but I do not have such an option (in windows 7 it was in the properties of the bar). Please write where I can find this option.
    Thanks,
    KP
  • #2 16485967
    yanes
    Help: 211
    Rate: 610
    Settings -> Personalization ---> Taskbar ---> Lock taskbar. Is not this what you want?
  • #3 16486446
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    If you want to change the way buttons group on the taskbar, press and hold or right-click any empty area on the taskbar, press or click Settings [rack icon], and then select one of the options in the Merge taskbar buttons list:
    Always, hide labels . This is the default setting. Each application is visible as a single unlabeled button - even if you open multiple windows of one application.
    When the strap is full . This setting shows each window as a separate button with a label. When there are many items in the taskbar, applications with open multiple windows are rolled into a single application button. Pressing or clicking this button displays a list of open windows.
    Never . This setting causes each window to be displayed as a separate button with a label. Windows are not connected regardless of how many of them have been opened. As you open more applications and windows, the buttons become smaller and eventually take up so much space that you have to scroll through them.
    I seem to be interested in the "Never" option - it disables grouping.
    Quotation from the article: https://support.microsoft.com/en-us/help/29280/windows-10-how-to-use-the-taskbar
