Renault Laguna II 1.9 dci: Broken V-Belt, Incorrect VIN Belt Length, 7-Row V-Belt Issue
Mr.Patryk 11859 9
What is the correct V-belt length for a Renault Laguna II 1.9 dCi with a 7-rib belt, and why does the replacement belt seem too long?
The correct belt length is 1790–1795 mm, so the replacement was not too long [#16486439] If a 1730 mm belt seems to fit, the old belt was likely routed incorrectly, and the guide roller should be between the alternator and the power steering pump [#16486827] In the end, the fault was not the belt length but a damaged crankshaft pulley that had fallen apart [#16490073] After replacing that part, the belt issue was resolved [#16490073]
  • #1 16486259
    Mr.Patryk
    Rate: 38
    Yesterday the V-belt broke, I bought the VIN belt but it turned out to be too long, which may be the reason. The car has a 7-row V-belt. Best regards
  • #2 16486303
  • #3 16486348
    mario 77
    Help: 66
    Rate: 335
    And the timing cover is complete, there is no belt residue under the pulley? Because it may turn out that the bar will not end.
  • #4 16486426
    Mr.Patryk
    Rate: 38
    I measured the old belt 173 cm or 1730 mm, and the new one that should fit is 179 cm or 1790 mm.
    The belt didn't break anything, it just broke.
  • #5 16486439
    ociz
    Help: 1379
    Rate: 3486
    You are assuming wrong. It is supposed to be 1790-1795.
  • #6 16486805
    Mr.Patryk
    Rate: 38
    I assume correctly, according to the scheme.
    Friend up: he says that I put it wrong, how do you explain that the old belt was 1730 mm?
  • #7 16486827
    ociz
    Help: 1379
    Rate: 3486
    The old one was probably badly inserted. The guide roller is to be between the alternator and the booster pump.
  • #8 16487029
  • #9 16487050
    Mr.Patryk
    Rate: 38
    This is a 1.9 dci engine, I am already correcting the title, from the phone the dictionary turned over sorry for the error.
    ociz as you showed the diagram so the new factory which should be factory or 1790 I had 6 cm of clearance. A new 1730 mm strap has been ordered and we will see. The old belt was not worn badly because it couldn't hold 45,000.
    My guess is that a wheel could be changed and therefore the size of the bar has changed.
  • #10 16490073
    Mr.Patryk
    Rate: 38
    The car has already been repaired and it turned out that the wheel from the crankshaft fell apart. And the strap is 1795 mm. I pay my honor
The discussion revolves around a Renault Laguna II 1.9 dci experiencing a broken V-belt. The user initially purchased a replacement belt that was too long, measuring 1790 mm compared to the old belt's 1730 mm. Various responses suggest that the issue may stem from incorrect installation or a potential change in components, such as the crankshaft wheel. Ultimately, it was determined that the correct belt length is 1795 mm, and the vehicle was repaired after discovering that the crankshaft wheel had failed.
