Hot Water Pump Stuck in 3rd Gear: Ferro Pump 25/40/180, 1-Year-Old, Speed Switch Issues
Skrokson 13050 10
Why is my Ferro 25/40/180 hot water circulation pump stuck on the 3rd speed, and what should I check or repair?
This pump is not controlled by electronics; it is a normal 3-speed circulator with a capacitor, so the first things to check are a weak capacitor, a corroded speed switch, a blocked impeller, or whether the pump shaft is mounted horizontally as required [#16488700][#16490412] The capacitor should be measured or replaced with one of the same parameters and size [#16490412] One reply also noted that the symptom can come from air in the pump, because after loosening the vent screw and releasing air, the pump started working again [#16521211] If the pump only runs properly at lower water temperature, that also points to a mechanical/airflow problem rather than “electronics” [#16488427][#16521211]
  • #1 16486591
    Skrokson
    Rate: 29
    For 2 days, the hot utility water pump is only in 3rd gear ... something could be done about it or the basket pump ... Ferro pump 25/40/180
    something like that
    https://onninen.pl/pl-PL/pompa...lid=CLvC6bqq tMCFRGMGQodS0QPaA
    Something seems to me that electronics could have fallen ... but it is true that the pump has about 1 year only unless the speed switch itself has died and you can do something with it.
    jack63
    Help: 851
    Rate: 2828
    Where do you have the electronics there?
    The capacitor has probably lost capacity.
    The link is not working.
  • Temperature drop restored normal pump speed switching
    #3 16488427
    Skrokson
    Rate: 29
    Well, electronics are just like the picture
    http://www.ferro.pl/produkt-pompa-cyrkulacyjna-2540180-2900-0201W.html
    only that the pump is horizontally and it is on the side
    but now one more temperature dropped to 29 * I was not at home so I did not need water and now it flashes normally in 1st gear and you can start all 3 gears
    and before that she worked for about 60 * as she jammed, i.e. what has some protection related to temperature I don't get it ...
    jack63
    Help: 851
    Rate: 2828
    There is no electronics. Normal 3 speed with capacitor. Open the cream and give photos.
  • #5 16490328
    Skrokson
    Rate: 29
    Hot Water Pump Stuck in 3rd Gear: Ferro Pump 25/40/180, 1-Year-Old, Speed Switch Issues Hot Water Pump Stuck in 3rd Gear: Ferro Pump 25/40/180, 1-Year-Old, Speed Switch Issues
    It looks like this
    and the second day the pump flashes normally
    jack63
    Help: 851
    Rate: 2828
    Well, where is the electronics?
    As you can see it can't be seen ...
    It could corrode the gear switch or the condenser lost capacity or the pump shaft was not horizontal (as pictured) or something blocked the impeller.
    Capacitor (this white "literary" :D ) must be measured or exchanged for the same in terms of parameters and dimensions.
  • #7 16521211
    Skrokson
    Rate: 29
    Okay, I know what kaman ....
    the action looks like that as the water in the oven heats up and the pump starts to work and heat the water, it sometimes fires up as it would seem to be the 3rd gear and it turns out that it seams up .... :| I just don't know why and that's why it is so strange .... at first I thought it was above 60 * to start to cool down or something but recently I unscrewed the vent screw, some air came down and suddenly it started to whip ...
    but why is it coming: /
    and it looks like this to me and it's about the red one ...
    • Hot Water Pump Stuck in 3rd Gear: Ferro Pump 25/40/180, 1-Year-Old, Speed Switch Issues 20170608_141327.jpg (1.71 MB) You must be logged in to download this attachment.
    • Hot Water Pump Stuck in 3rd Gear: Ferro Pump 25/40/180, 1-Year-Old, Speed Switch Issues 20170608_141322.jpg (2.06 MB) You must be logged in to download this attachment.
  • #8 16525071
    jack63
    Help: 851
    Rate: 2828
    Skrokson wrote:
    but why does it announce itself
    difficult to determine. Your photos don't show it. Not enough information. You would need to provide more information to help you. Scheme + more photos + description.
    One thing you can see is the lack of an expansion pipe from the boiler. The boiler looks solid fuel, so it requires an open system, unless it has a cooling coil.
    From the pictures you can see that the pumps "fight" for water when they work together.
  • #9 16525965
    Skrokson
    Rate: 29
    hmmm
    Well, from the oven, as you can see, it goes to the pump from the radiators, i.e. the blue and red one goes to the water. Now I have the pump from the radiators set to about 70 * so that it does not start without the esu and pounds the radiators for now, because it heats the water from time to time . next to the tank 300L galmeter 2 coils prepared for solar and for now the oven connected only to the upper coil. furnace hmmm well, everything old gniot 25kW is over 10 years old and you have to think about change. the boiler room is in the basement, you can say it is on the ground floor and the boiler room is a little below the building from the 70s ... there is a floor where it lives and the toilet has a rudder overflow regulator from radiators.
    in the photo there is a baniak now I have installed the heater we will see what it will do like 2kW galmet only that they write to mount the cable down I did not quite succeed
    a draft regulator is installed on the furnace that opens and closes the flap at the bottom of the furnace and gives a squeeze
    There is a little old installation here and a little new, unfortunately there was no cash for the exchange of pipes so I go on what is fortunately if one day I start to change the pipes it is a lot of work and all the pipes that I need go through the boiler room or garage to me downstairs is fine so downstairs will be renovated one day.
    • Hot Water Pump Stuck in 3rd Gear: Ferro Pump 25/40/180, 1-Year-Old, Speed Switch Issues 20170612_181446.jpg (433.96 KB) You must be logged in to download this attachment.
    • Hot Water Pump Stuck in 3rd Gear: Ferro Pump 25/40/180, 1-Year-Old, Speed Switch Issues 20170421_194650.jpg (2.07 MB) You must be logged in to download this attachment.
    • Hot Water Pump Stuck in 3rd Gear: Ferro Pump 25/40/180, 1-Year-Old, Speed Switch Issues 20161117_113616.jpg (1.26 MB) You must be logged in to download this attachment.
    • Hot Water Pump Stuck in 3rd Gear: Ferro Pump 25/40/180, 1-Year-Old, Speed Switch Issues 20160907_113854.jpg (1.07 MB) You must be logged in to download this attachment.
  • #10 16532796
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6438
    Why do you have such a small pump to heat water and in addition it is not a circulating pump.
    Has it ever worked at all?
  • #11 16532878
    Skrokson
    Rate: 29
    you know what I don't know, I don't know that much ... such was the plumber that assembled the boiler and is to install solar panels in the future .... generally the pump pumps and charges the boiler I don't know if it's too small or too big
    And as to whether it is circulating or not, I don't know, and should it be? but it says it is a circulator so it probably is
The discussion revolves around a Ferro Pump 25/40/180 that is stuck in 3rd gear, with the user suspecting issues related to the speed switch or electronics. Initial troubleshooting suggests that the capacitor may have lost capacity, and there are concerns about potential blockages or corrosion affecting the gear switch. The user reports intermittent normal operation after a temperature drop, indicating possible thermal protection activation. Further analysis reveals that the pump may not be suitable for the heating system's requirements, and additional information about the system setup is needed for accurate diagnosis. The user is uncertain about the pump's specifications and whether it is a circulating pump, as it was installed by a plumber.
