MH 1300 Water Pump: Single-Phase Motor Hums, Random Engine Start Issues & Capacitor Replacement
Lewuski510 19002 9
Why does a single-phase water pump motor hum and fail to start intermittently, and what parts should I check or replace?
The most likely cause is a weak or faulty 25 µF start capacitor, so measure its capacitance and replace it if needed, since this motor uses an auxiliary phase and has no centrifugal switch [#16677969][#16677992][#16678406] If the capacitor is good, check the auxiliary winding and its connections for a break or bad joint, because one case showed a winding connection effectively "welded"/open [#16677997][#16678406] The motor also has very low starting torque, so even slight mechanical drag, such as the rotor rubbing the housing, can prevent starting [#16679969] Voltage drops were mentioned as a possible factor, but the reported mains voltage of about 215 V was considered within tolerance [#16679445] In the thread, replacing the 25 µF capacitor resolved the starting problem [#16710589]
  • #1 16677908
    Lewuski510
    In the MH 1300 water pump, when the power is turned on, the engine buzzs from time to time and does not want to "start". Sometimes you need to turn it on 3 or 4 times to make it surprise. The problem is that the next few days work properly, and then a few times will not surprise. I checked connections and it's about key. I'm going to replace the capacitor - 25uF / 450V but I don't know if it will help. What could be another reason for a random engine start? I have several other single-phase motors and it has never been such a problem. I am asking for possible fault locations
  • #2 16677969
    DriverMSG
    Help: 3984
    Rate: 4878
    Replace and check. The capacitor is responsible for starting the engine.
  • #3 16677992
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    Before replacing the capacitor, measure its capacity, and first of all check the operation of the centrifugal switch, because it probably appears in this engine - there I would look for the cause of your "pain".
    Read section 3.1.15 of the forum rules and correct the title in the first post!
  • #4 16677997
    robokop
    Help: 1763
    Rate: 6370
    There is no centrifugal switch, it is a motor with an auxiliary phase. Evidently a capacitor to be replaced - I used to do an autopsy out of curiosity, it turned out that the removal of one of the linings was "welded".
  • #5 16678007
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    I wouldn't be so sure. However, if you are right - the author will confirm, I face. :wink:
  • #7 16678406
    robokop
    Help: 1763
    Rate: 6370
    I disassembled several versions of these pumps - 2800rpm engine, with a capacitor of 10-20uF, depending on the power. The described symptoms actually in the case of a "civilized" engine would indicate a centrifugal switch, but there is no such. And as I wrote - a capacitor to replace, possibly a break in the winding - sometimes the aluminum winding is badly connected to the copper wire.
  • #8 16679445
    Lewuski510
    Thanks for the information. I contacted the company service and confirmed the lack of a centrifugal switch. The only thing that makes me wonder is that the engine humming can be unpredictable. For 2 - 3 days it's about the key, and the next time I need to turn on several times before it clicks. The service also could not (or did not want to) provide any specific information apparently this could also be due to voltage drops. In my case, the voltage does not drop below 215 V, i.e. within tolerance. They suggest delivering to the service but the randomness of failure causes that I have little hope that they will be able to identify the fault. For this reason, I am using the forum to try to eliminate this fault.
  • #9 16679969
    robokop
    Help: 1763
    Rate: 6370
    Rather, deliver this pump to the service. This engine has a viciously low starting torque and any load on the shaft can prevent it from starting - even slightly rubbing the rotor on the body.
  • #10 16710589
    Lewuski510
    As suggested by some Internet users and after consulting a company from Toruń, I replaced the 25 uF starting capacitor and it's about key.
✨ The discussion revolves around issues with the MH 1300 water pump, specifically related to its single-phase motor that intermittently hums and fails to start. Users suggest that the capacitor, rated at 25uF / 450V, is likely the culprit, as it is essential for starting the motor. Some responses recommend checking the capacitor's capacity and the potential for a break in the winding connections. The absence of a centrifugal switch in this model is confirmed, leading to speculation about low starting torque and possible mechanical binding. The author ultimately replaced the capacitor, which resolved the starting issues.
